Similar Content
By PWL216
Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
By BobandJamie Raay
400 Series WheelHorse Garden Tractor w 42" deck in good condition. Has a frame issue under the seat (needs welding) but runs well. 17-horse Kohler engine on tractor.
Extra rear discharge mulching deck (42"), extra set of blades for mulching deck and side discharge deck, snow thrower (42" with 20" chute) and trac vac with 5.5 horse Honda engine in good, working condition as well. All 4 hubcaps are included (rear not in tractor picture but see additional pic). Original paperwork, including owner's manual on all. Includes chains for snow traction and weight attachments for each wheel. All have been used at the same property since purchase and have been stored indoors throughout. Thanks for looking!
By Bostman67
1967 Wheel Horse 1277 - Kohler K301S, gas engine, belt driven, hydrostatic. I had it running recently but then attempted some electrical work. I also cleaned it up by sanding some rust, dirt and grime off body and engine. Some new parts were added like a new choke cable, ignition switch, head lights, spark plug, battery and battery cables. I have new seat and some other parts that I will never use if sold. The implements include a tiller, snow thrower, mower deck. I've never attached these items. I have some belts and pulleys that came with it when I inherited it. It's easily accessible for removal and showing.
IMG_1727.MOV
By wh315-8
Looking for the measurements for items #69 mounting bracket and #79 lifting rod. So that I could fabricate and be able to install on my RJ59. Any pics of the mounting bracket would be a big help.
By wh315-8
Just recently purchased a 1964 34R and a separate deal landed a Snow Thrower, believe it to be a ST323 maybe a 324. It does not have the idler pulley. I did find posts for measurements on the pulley arm for Ranger. I need close up pics of the ends of the clutch rod and the crank rod as well as measurements so that I can fab these parts. Or if anyone has these parts for sale I would be interested.
