mrc 1,122 #1 Posted November 3, 2015 hi men, is there a source for "rubber bumpers" where say a flip up fender pan hits the cross brace when latched in the down postion? also the fender pan always rubs the upward part of the floorboard. any ideas on how to cushion that area? thank you mike in mass. Share this post Link to post Share on other sites
Brian01 481 #2 Posted November 3, 2015 (edited) Small rubber hose, slit it from one end to the other and put on the edge...or an old inner tube glued down to the cross bar?Or 3Mshould make some sort of stick on pads for cushioning. Edited November 3, 2015 by Brian01 Share this post Link to post Share on other sites
953 nut 70,330 #3 Posted November 3, 2015 Give this a look.http://www.steelerubber.com/bumpers 3 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted November 3, 2015 @953 nut that is a good site for rubber (baby buggy) bumpers! Lots of options. 3 Share this post Link to post Share on other sites
Trouty56 568 #5 Posted November 3, 2015 I got some a while back....here is a link to the post...someone else found them.....http://www.wheelhorseforum.com/topic/51581-seat-bumperbushing/#comment-475265 Share this post Link to post Share on other sites
Gary L. 12 #6 Posted November 4, 2015 I get these "push in rubber bumpers" from ebay, they are 1" diameter and 5/16" thick, I sand them downon a belt sander for a good fit usually a little less than 1/4" 1 Share this post Link to post Share on other sites
kudzu3 323 #7 Posted November 4, 2015 I use auto door edge trim on the pan where it rubs the upper part of the running boards. I also use it on the back of the pan where it rubs the tires when it is in the up position. I have a B 80, show tractor that I put the door edge all the way around the pan...looks good too. Share this post Link to post Share on other sites
ronhatch 410 #8 Posted November 4, 2015 Try McMaster-Carr. They have everything! Share this post Link to post Share on other sites
