boovuc 1,090 #1 Posted October 25, 2015 Well I have my new to me Original Tractor Cab on my C-175 but I noticed that the chute rotator handle is too short. It won't go all the way into the cab through the little slit in the cab opening.Was there an extension that you could purchase from Wheel Horse for this application? I need about 8 to 12 inches. (Don't we all).Thanks in Advance! Share this post Link to post Share on other sites
Kurt-NEPA 755 #2 Posted October 25, 2015 I'm not sure about your C175, but on my 520H and Original Cab, there is an extension tube, about 12" long. It came with the cab. It moves the crank rearward and inside the cab.Kurt Share this post Link to post Share on other sites
MalMac 1,332 #3 Posted October 25, 2015 Yep the extension came with the cab. Also a L bracket that mounted to the frame of the cab help support the lever. Share this post Link to post Share on other sites
squonk 43,926 #4 Posted October 25, 2015 I solved this by buying a chunk of 3/8 round stock from TSC and got a 3/8" shaft coupler from a hardware store. Cut the length needed and drilled a hole for the snap pin. added the coupler and put the existing rod in and done! Share this post Link to post Share on other sites
boovuc 1,090 #5 Posted October 25, 2015 Thanks guys! This is what I thought and I know where the extension is!Oh Chev0545! Dave! Oh buddy! I need something from you! It's on your tractor most likely! 1 Share this post Link to post Share on other sites
boovuc 1,090 #6 Posted October 26, 2015 Yup! It was on Dave's tractor. The L shaped bracket was already on the frame and your right. It does help support the extra length.Thanks again! Share this post Link to post Share on other sites
squonk 43,926 #7 Posted October 26, 2015 Here's my extension. 2 Share this post Link to post Share on other sites
boovuc 1,090 #8 Posted October 27, 2015 Looks better than the cotter pins sticking out of the supplied extension! Share this post Link to post Share on other sites
