SylvanLakeWH 29,888 #1 Posted October 17, 2015 I have a 1982 C-105 8 Speed. It is new to us a couple months ago, but it sat for 3 years in a garage after light lawn duty for 20+ years at my brother's house. Price was right (Free) and it runs great, shifts good, no noticeable problems...So... It's been "a while" since transmission oil has been changed.Went to check level the other day and level is fine but it was a creamy color and had small bubbles in it - cold. This seems odd and before I just change it and move on, should I be concerned? What kind / weight oil should I use? How much? Suggestions?What say ye? Thoughts / advice appreciated. Share this post Link to post Share on other sites
doc724 925 #2 Posted October 17, 2015 If it is creamy, that means that there is water in it. The likely entry point is a deteriorated rubber boot around the shift lever. If you are going to change it, buy a new boot as well. Transaxle takes 2 quarts of gear oil. Old WH manuals say 90W-145, (I think) but based on others experience here, I have been using 85W-90. Since the drain is in the back half of the transaxle (on the bottom) make sure you raise the front of the machine a bit to get as much oil as possible "over the hump" in the bottom of the transaxle so it can drain out. Gear oil stinks so if you do not like the smell, replace it with synthetic. The stink however is useful because if you can smell it, it means there is a leak somewhere. Share this post Link to post Share on other sites
tunahead72 2,591 #3 Posted October 17, 2015 You might want to follow along on this thread too:http://www.wheelhorseforum.com/topic/59627-312-8-transmission-oil-change-issue/ 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,888 #4 Posted October 17, 2015 THANK YOU!Appreciate the help! Share this post Link to post Share on other sites
Lagersolut 770 #5 Posted October 17, 2015 (edited) Whenever I drain a trans - after raising the front and leaving it run out awhile ( I always do mine in warm weather so the oil is thinner and runs better ) I'll turn down the pressure on my compressor to like 20-30 lbs and use the air nozzle to gently and slowly push the remaining oil out - too fast and too much pressure you'll have oil everywhere - slow and easy works great..... use a rag to seal around the nozzle so it pushes out the drain hole . Edited October 17, 2015 by Lagersolut Share this post Link to post Share on other sites
SylvanLakeWH 29,888 #6 Posted October 17, 2015 Great idea! Thank you! Share this post Link to post Share on other sites
SylvanLakeWH 29,888 #7 Posted October 19, 2015 Tranny oil changed (yuck factor very high and thick)...Mission accomplished using your suggestions! Thank you much!As newbie both to WHs and transmissions, it went just as noted in the replies / threads...Once again - well worth being a supporter... Share this post Link to post Share on other sites
tunahead72 2,591 #8 Posted October 20, 2015 Good to hear! Share this post Link to post Share on other sites
