steve k 82 #1 Posted October 7, 2015 (edited) I got sick and tired of messing around with the vacuum fuel pump on my GT 1100. It has the 11 hp briggs. So after some thought I went to napa today to see about a universal electric pump.I also think this may be good for one of my kohlers if ever those pumps fail. The one I got is PN 610-1051 it says 1.5-4 lbs of pressure. It is actually better than I expected, seems well built, comes with a filter for the inlet side and a hose barb for the outlet(brass even!) The pump is 1/8 inch female pipe thread on both ends. Seems to work great. I jumpered it to run constant while checking for leaks and found none, float seems to hold needle shut just fine. The cost was a little tall at $50 but some of the replacement mechanical pumps are near that and it seems like it will last. Anyway thought I would pass it along. Edited October 7, 2015 by steve k 2 Share this post Link to post Share on other sites
mikekot3 93 #2 Posted October 7, 2015 Sound like a nice pump but make sure to have it run only when cranking and running the engine otherwise you can hydrolock the engine with gasoline and bend connecting rods. Share this post Link to post Share on other sites
squonk 47,439 #3 Posted October 7, 2015 http://www.wheelhorseforum.com/topic/34909-installelectric-fuel-pump-on-a-c-160/http://www.wheelhorseforum.com/topic/38994-electric-fuel-pump-revisited/ 1 Share this post Link to post Share on other sites
steve k 82 #4 Posted October 7, 2015 Great minds think alike Mike! Yes the pump is wired to only be on when engine is running. Share this post Link to post Share on other sites
JackC 619 #5 Posted October 7, 2015 I connect the positive lead for the electric fuel pump to the positive lead on the coil. Is that a good point to get power to the pump?My 8 hp Kohler on my C-81 now starts instantly. My starter loves it.I also use clear fuel line near the engine so I can see the juice feeding those 8 horses. If it don't start it ain't fuel delivery. If it is I can plainly see it. Share this post Link to post Share on other sites
steve k 82 #6 Posted October 8, 2015 It will probably be fine Jack. Share this post Link to post Share on other sites
