chorusguy 227 #1 Posted October 4, 2015 Is the only difference engine size? Share this post Link to post Share on other sites
fireman 1,022 #2 Posted October 4, 2015 That's it I believe. Other then that they should be the same. Only possible differences is between the years they were made. The "C" series was manufactured from 1974 till 1984.Possible changes are as follows:Axle diameter: At some point they went from a 1" axle to a 1 1/8" diameter (not sure if was done during their production)Seat: the seats went from a two piece design to the standard one pieceControl console/tower: they changed the styling of the steering tower/console between 1977 and 1978.Model changed from C-120 to C-121 and C-160 to C-161 in 1978 Share this post Link to post Share on other sites
squonk 43,730 #3 Posted October 4, 2015 Don't know what year they changed but some had flip up rear fenders and some didn't. My 76 C-160 has the flip fender but I'm told it wasn't supposed too. Share this post Link to post Share on other sites
daveoman1966 3,839 #4 Posted October 4, 2015 Don't forget... the C-160 gives YOU bigger balls. too. 6 Share this post Link to post Share on other sites
can whlvr 994 #5 Posted October 4, 2015 1976 didn't have flip seat,75 did,but I do believe that goes for both the 160 and 120 Share this post Link to post Share on other sites
Ed Kennell 41,797 #6 Posted October 4, 2015 (edited) My '74 C-120 has a HH120 Tecumseh with a Sundstrand 90-1136 hydroThe '75 C-160 has a K341 Kohler with a Sundstrand 90-1140 hydro.Both have two piece seats and flip up fender/seat pans.The 160 has a different knob on the F/R lever than the 120. 160 knob 2 5/8" long 120 knob 4 5/8" long Edited October 4, 2015 by ekennell 2 Share this post Link to post Share on other sites
AMC RULES 37,196 #7 Posted October 4, 2015 So, then... some bigger knobs too. 5 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #8 Posted October 4, 2015 My '74 C-120 has a HH120 Tecumseh with a Sundstrand 90-1136 hydroThe '75 C-160 has a K341 Kohler with a Sundstrand 90-1140 hydro.Both have two piece seats and flip up fender/seat pans.The 160 has a different knob on the F/R lever than the 120. 160 knob 2 5/8" long 120 knob 4 5/8" long 2 inches could make a difference to some humans. Share this post Link to post Share on other sites
Ed Kennell 41,797 #9 Posted October 4, 2015 Breaker...Breaker, where you at Sparky ??? So, then... some bigger knobs too. Yep, the little 120 w/Tecky has a bigger knob......go figger 2 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #10 Posted October 4, 2015 Are you looking to buy a C120? Share this post Link to post Share on other sites
chorusguy 227 #11 Posted October 4, 2015 Not really. I have 5 160s but was curious about parts interchange in cas I somehow need a part I don't have on my parts tractor Share this post Link to post Share on other sites
Wheel-N-It 2,976 #12 Posted October 4, 2015 Not really. I have 5 160s but was curious about parts interchange in cas I somehow need a part I don't have on my parts tractor Oh OK, I was thinking you might be adding another Horse to the herd Share this post Link to post Share on other sites
fireman 1,022 #13 Posted October 4, 2015 I forgot about the different hydro transmissions. Here are some screen shots from the master list that lists the model number, year, engine, transmission etc. for all the "C" series 2 Share this post Link to post Share on other sites
squonk 43,730 #14 Posted October 4, 2015 1976 didn't have flip seat,75 did,but I do believe that goes for both the 160 and 120 But my 76 does and everythinglools orginal Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #15 Posted October 4, 2015 I was looking art the screen shots provided by fireman and I wonder if anyone knows the difference between the 1974 1-0485 and 1-0490 C120 tractors. Both have 12 hp Kohler motors and both have Sundstrand 90-1136 transmissions. It seems that this happens in other years , different model numbers but the same Manufacture modle and Hp engine and the same model transmission. Just wondering . Share this post Link to post Share on other sites
Ed Kennell 41,797 #16 Posted October 5, 2015 Could that have been with and without hyd lift cylinder ? Share this post Link to post Share on other sites
chorusguy 227 #17 Posted October 5, 2015 Not really. I have 5 160s but was curious about parts interchange in cas I somehow need a part I don't have on my parts tractor Oh OK, I was thinking you might be adding another Horse to the herd there is a cheap one in Pittsboro but since the hydro's are different i think I'll pass. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #18 Posted October 5, 2015 Yes I seen that one too and decided to pass because I'm a gear drive guy, not really into hydros on small tractors. The hydro soaks up too much power before it has a chance to do anything else. 1 Share this post Link to post Share on other sites
squonk 43,730 #19 Posted October 5, 2015 My 160 is a hydro and I'll never be with out it. It all depends on what kind of work your doing with it. With my yard, I can cut 20 minutes of mowing time out with a hydro over an 8 spd. 1 Share this post Link to post Share on other sites
Racinbob 11,919 #20 Posted October 5, 2015 chorusguy, you're showing that you have a 74, 75 and 76. Go look at them. Virtually every part will obviously interchange. Per the original parts list the 75 8 speeds had a flip fender, the 75 autos didn't. Supposedly all the 76 models had a fixed fender and the seat flipped forward (as was mine). Are we confusing flip fender and flip seat? But I would bet if they some 75 flip fenders left over in they made it on the 76 tractors. It's also a very easy swap with no modifications to bolt a flip fender on one that originally wasn't. Forget the knobs, That's hardware store stuff and who's to say with certainty after 40 +/- years? I've also seen items like that be different even with the same part number directly from Wheel Horse. So, if you're just looking for a parts tractor and you have all 8 speeds maybe a hydro isn't for you but there's still a lot of common parts. Oh, your 74 and 75 have hood ornaments and the 76 doesn't but if you swap a hood does that mean........... Share this post Link to post Share on other sites
chorusguy 227 #21 Posted October 5, 2015 Right. I have 5 c160 autos. One being a parts tractor and have no concerns about parts interchanging. But in my area there are a couple of 120's near me for cheap and was wondering how much they would interchange especially transmissions. Thanks to the good information given here I see that the transmissions are different. Sobnow I know that I will be better served to stay focused on c160s. My 76 has a non-flip fender. The rest have fenders that flip up. I haven't checked the years on either my parts tractor or the most recent worker I got.Thanks to all for such good info. Share this post Link to post Share on other sites
Ed Kennell 41,797 #22 Posted October 5, 2015 (edited) Does anyone know what the difference is between the Sundstrand 90-1136,37,40 hydros used in these C- 120s and 160s ?I suspect they may all be physically interchangeable. Edited October 5, 2015 by ekennell Share this post Link to post Share on other sites
tbarnhart 240 #23 Posted October 6, 2015 Ed, I'm agreeing with you on the Hydro lift valve as the only difference in the trannys. The 74-75 160 autos all came with the hyd. lift, but the 120 autos still had the manual lift like the 8-speeds. The transmissions are alike except for a few valves and springs that have to be changed to provide power for the lift valve. I don't know the specifics on that, but it's here with a bit of searching. As far as the basic pump, motor, and transaxle, they were the same stuff. The rest of the tractor was the same as well except the engine and a few extras on the 160 such as an hour meter and armrests. Frame, sheet metal, axles, wheels, etc. were the exact same within a given year. There were a few changes as mentioned between the early (74-75) and the late(76-77) 120s and 160s. 1978 brought the C-1x1 series that looked a lot the same, but had quite a few differences. 1 Share this post Link to post Share on other sites
can whlvr 994 #24 Posted October 7, 2015 my 75 auto has the flip fender and is original Share this post Link to post Share on other sites
