mikekot3
Wheel horse seat change from stock to something better
mikekot3
Hello Red Square folks,
I was wondering if any of you folks had mounted some other seats other than the stock one on a tractor like on a 416-8 or the like.
I have been looking online on a bunch of websites for other application stock seats like on a zero turn mower and universal type seats.
I was considering trying to find a seat with the operator presence switch in them for about 200 dollars or other ones that do not have that feature
for about 80-125 dollars. The seats typically found on ZTR mowers look very nice if they had suspension or not versions.
if I removed the spring steel c-shaped seat bracket riser from the swing up mount would there be sufficient space between the steering wheel?
Any other suggestions would be appreciated. If I purchased a seat without the operator presence switch do I need to install a loop back plug in the wiring harness under the seat for the machine to start and run?
Edited by mikekot3
Bow_Extreme
You can easily purchase a seat without the switch.  You can mount a simple switch in the seat pan to activate once you sit in the seat.  My 520H has this option.  If you remove the C springs I don't think you will be able to adjust the seat back far enough.  You need this height to clear the pan.  I just installed a seat from family farm and home on my 520H.  It was about $150+
boovuc
Mike,
Take your stock seat to an automotive reupholster and have it done for a 1/3 or less of the price of a replacement seat. Ask the body shops around your town where they send their clients for upholstering and get an estimate. I have had two done local upholster who has been in constant business for over 50 years. Heavy vinyl! Quality work!. Comfortable! More so than the stock 417 seat! 50 bucks!
If you buy an after-market seat, read the reviews for it before buying. Many of these cheaper seats disintegrate with not much exposure to the sun. Florescent lighting kills them too!
Horse46
I don't know what type of seat you are after but I have just fitted one of these to mine, its nice n comfy to with a back rest fitted. See ID 32
Edited by Horse46
mikekot3
Hello Horse46,
Where did you get the seat and what is the make and model number?
Thank you,
mike
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • rustyedge1
      By rustyedge1
      Looking at this Ferris seat and wondering about the issues I may encounter in trying to switch out entire seat on the 417 or even if it can be done ?
      Any info would be appreciated and thanks in advance.
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
    • SOCKDOG
      By SOCKDOG
      I have a 1963 633 with the steal Square pan seat. It is cracked and looking to replace it. I can find loads of the standard round replacement seats but not a square one. Does anybody know where I can find one?
