chorusguy 227 #1 Posted October 2, 2015 Need to cut a trench for a french drain. Has anyone ever fabricated an implement for this task or is there an existing implement that will do that? Share this post Link to post Share on other sites
wallfish 20,513 #2 Posted October 2, 2015 (edited) YUP, made this attachment but not for a french drain. Buried my utilities and other things but doubt this will help you at the moment.How deep do you have to go? Maybe you can rig something up with a moldboard plow. Dig as far as it will go hooked up normally and then fabricate something to hold it down deeper in the trench??? Just thinking out loud. Check out this cool attachment.https://www.youtube.com/watch?v=NBAzvl95BGk&feature=youtu.beIf you have quite a bit to do you can rent a real trencher for the day. Edited October 2, 2015 by wallfish 2 Share this post Link to post Share on other sites
chorusguy 227 #3 Posted October 2, 2015 Very impressive but way way beyond my ability. I do have a moldboard plow through Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted October 2, 2015 I once used a skid-steer loader with pallet forks to dig a drain-line some 60' or so.Put the forks side by side and a little forward tilt and dug the trench about 12" deep from the house to the ditch. 1 Share this post Link to post Share on other sites
chorusguy 227 #5 Posted October 3, 2015 Just to clarify. Wondering about some sort of rig for a wheelhorse. Like maybe a tool bar with some sort of spade attached.thanks Share this post Link to post Share on other sites
boovuc 1,090 #6 Posted October 3, 2015 My neighbor used his Xi WH to trench a dog fence wire around his yard by using a 3/4" all thread bar through a simple modified hitch attachment. The tractor's weight plus his own weight and low range and he simply drove his tractor around the perimeter of the yard. It was NOT without hiccups! :< ) He hit rocks! He bent the bar several times! He rattled it loose several times but he accomplished the wire hide in a fraction of what it would have taken him by hand. I did the same thing with for my Dish Network install for 50+ feet in my side yard. This buried it 6 to 8 inches. If your doing a water line below frost level or electric lines to code, it won't work.PS........This doesn't work in Mid August/Dry cracked yards! 1 Share this post Link to post Share on other sites
