Shuboxlover 484 #1 Posted September 10, 2015 I have a B-100 Auto that needs an axle. (right hand although I believe they're the same) I have a rear end from a 314-8. I was looking on the Toro MPV and it appears they share the same axle.Can this be true? They are both 1" axles but one is a hydro and one is an 8 speed and 10 years apart in age.Can someone confirm this before I tear into it and it ends up being the wrong one.Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #2 Posted September 10, 2015 The 1" axle for the B-100 Auto is part number 5961. Is that the one you are looking at?A thread about 1" hydro axles recently came up. I see the 1972 Charger 10 model 1-0410 also uses the 1" 5961 axle. Thank goodness for original ipl's.What year is the 314-8? Those ipl's are a mess at Toro.Garry Share this post Link to post Share on other sites
Shuboxlover 484 #3 Posted September 10, 2015 (edited) Hey Garry, thanks for the response!Yes, I see that the B-100 takes the 5961.The 314-8 I am talking about was a 1985 (Model# 21-14K801) Hope this helps solve this mystery.Thanks a bunch! Edited September 10, 2015 by Shuboxlover Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #4 Posted September 10, 2015 You have a 21-14K801 with 1" axles so that is the best evidence we have since an original parts list has never shown up yet.The Details page at Toro shows the 314-8 using a 103916 transmission with 1-1/8" axles and 8 pinion gears which is wrong.It should be a 110996 transmission with 1" axles and 4 pinion gears like the 1985 models 310-8 and 312-8The 103916 transmission with 1-1/8" axles and 8 pinions was used 1978-1984.This was replaced with the 110995 used 1985-1993Garry Share this post Link to post Share on other sites
Shuboxlover 484 #5 Posted September 12, 2015 Soooo.........In your humble opinion, will the 1" axle from the 8 speed work in hydro transmission? Share this post Link to post Share on other sites
stevasaurus 23,536 #6 Posted September 12, 2015 It should work. The differential in a hydro is the same as the differential in a manual transmission. If they are both 1" axles with 4 pinion differentials, I would go for it. Share this post Link to post Share on other sites
