Wheel Horse Sweepster Started by 1978c81 in Forsale
By
DennisThornton, in Implements and Attachments
Similar Content
By sjoemie himself
Hi all.
This topic will be dedicated to the upgrades and modifications I'm going to do to my 512-D with sweeper attachment.
The plan was to complete my mini IH 1468 before starting to work on the Wheel Horse but since the leaves are coming down quick I developed an 'itch' to get working on the Wheel Horse.
First things first, I had to get it running again. New ignition switch and new inline fuse, aswell as cutting out all unnecessary (for now) stuff solved the non-running issue.
Dashboard wiring seems to be OK
This is a mess. Two unnecessary relais, one unnecessary switch and a bunch of unnecessary wires everywhere.
Next up will be a new battery and probably some modifications to the pto-clutch and new oil all around. Also I'm on the lookout for new filter elements for the oilbath filter for the Robin DY41D engine.
Done for now.
Major upgrades and or restoration will have to wait until after I finish the Murray to IH 1468 project.
Running again. Listen to that THUMP!
Almost forgot to mention.. probably needs some new rubber mounts
Greetings from the Netherlands, Mark
By sjoemie himself
As requested some pictures of my 1986 Wheel Horse 512-D with sweeper attachment.
