Lane Ranger 11,395 #1 Posted September 4, 2015 (edited) I recall a member on Red Square was making 42 inch wearbars for snow plows ( I think I bought one or two) but I do not recall anyone making 54 inch plow wearbars or cutting edge as some may call it. Anyone know a source for a new one of these? I see some snowplow supply companies will make synthetic material wearbars to order but I would like to get a metal one. May have to make my own !I believe the original part number was #3087 but no longer available tru Toro according to Partstree.com website. Edited September 4, 2015 by Lane Ranger Share this post Link to post Share on other sites
squonk 43,777 #2 Posted September 4, 2015 Anybody near you build those custom sno-pushers for loaders Lane? They could cut you any length you need. 2 Share this post Link to post Share on other sites
Aldon 4,828 #3 Posted September 5, 2015 I could use one as well. Hopefully someone chimes in with easy button. 2 Share this post Link to post Share on other sites
slammer302 2,156 #4 Posted September 5, 2015 if you guys were closer i could cut sum metal down for you 3 Share this post Link to post Share on other sites
Aldon 4,828 #5 Posted September 6, 2015 Thanks! MO is a long way to go for some steel for sure:-) 2 Share this post Link to post Share on other sites
JPWH 6,338 #6 Posted September 6, 2015 Check with a local metal fabricator. I deal with a shop that sells cut lengts by the pound. Comes out to about 1/2 of retail store short length prices. They also have a better selection and will make cuts if you want. 1 Share this post Link to post Share on other sites
Lane Ranger 11,395 #7 Posted September 6, 2015 I found a family owned steel business that makes sno-pushers near me that said to bring in the wearbar from the 54 inch Wheel Horse plow and they could make a rubber/composite wearbar or steel bar when they had the bolt pattern setup. Not sure of cost but I am going to check it out. Thanks for the suggestions ! 1 Share this post Link to post Share on other sites
Lane Ranger 11,395 #8 Posted September 10, 2015 Ok folks this is what we are going to be using (at least my brother David will be using it) for a wearbar on the 54 inch snowplow I bought from a member in Bel Air, Maryland. I took the suggestion to find a company that fabricated snowpushers. I called and spoke to the company and they said they thought they could help make what I needed using rubber composite like they use on parking lot snow pushers. I took the old 54 inch wearbar to use as a pattern for the holes. They cut slots in the rubber (which is 1 inch thick by the way) and made a meatal cover plate with 3/8th inch holes drilled to hold the rubber wearbar on the front of the 54 inch Wheel Horse snowplow. The wearbar is 6 inches high -about twice what I think I needed but it can be turned over and slid up and down if it wears very much. The snowpusher company folks told me this wearbar will last a very long time. We will see but I was impressed that they did all this in two days. I paid $111.95 for this but I always wanted to see if this composite material might work on one of these snowplows for a wearbar. I guess we will get to find out this winter. I will keep Red Square posted. 5 Share this post Link to post Share on other sites
zekepiks 8 #9 Posted September 11, 2015 I made a post about this once before but it might help someone as much as it helped me, I'm in southwest Michigan and I went to ALRO steel in my area and bought a piece of of ( I think ) 3 inch by 1/4 , had them cut it to length for 50c or 1.00 and then they punched the square holes for the stove bolts for a dollar a hole. it worked great and think it all cost about 12.00 to 15.00 dollars 3 Share this post Link to post Share on other sites
bmsgaffer 2,053 #10 Posted September 11, 2015 THAT is a wear bar!I look forward to your report on how well it works and wears, I too have been curious about the plastic or rubber materials. 1 Share this post Link to post Share on other sites
RedRanger 1,469 #11 Posted September 15, 2015 (edited) I put a composite wear bar on my blade last season. Works great and doesn't scratch my black top.Drill your own holes.http://www.ebay.com/itm/HEAVY-DUTY-54-POLY-WARE-BAR-JOHN-DEERE-WHEEL-HORSE-CUB-CADET-BOLENS-SNOW-PLOW-/261634661189?hash=item3ceaa41b45 Edited September 15, 2015 by RedRanger 2 Share this post Link to post Share on other sites
Lane Ranger 11,395 #12 Posted September 15, 2015 Red Ranger: Thanks for the info. I would prefer to see it 3 inches high but the one I got was six. Sounds like you had good luck with it. My brother is going to be using this real close to you in Calumet Township -where you get those real winter snows!! 1 Share this post Link to post Share on other sites
RedRanger 1,469 #13 Posted September 15, 2015 (edited) I used it all winter. Worked as good as, or better than, a steel cutting edge. Very hard material, yet slides like a plastic. Drills like steel.No noise. No scratches on the sealcoat. On a smooth blacktop drive, I'd bet it would last 20 years or longer. I also plow about 200 feet of brushed concrete sidewalk which I noticed files it down some.I'm guessing I'll get about 3-4 years of use before I need to flip or replace it.Had a fresh coating on the drive last fall before winter and in the spring, you could not tell it was ever plowed. A lot of commercial snow removal companies are going to this stuff for their trucks. We sometimes get real winters, lately not so much though. Edited September 15, 2015 by RedRanger 3 Share this post Link to post Share on other sites
