rracioppi 2 #1 Posted September 2, 2015 I have a 78 or 79 not sure C 121 8 speed, I want to get a mowing deck for it but not sure where to find the specs on which ones fit? If anyone knows what decks fit this model I would appreciate the info. Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted September 2, 2015 (edited) Virtually ANY of the 36 42 (side or rear disch) or 48" side disch decks with the Tach-o-Matic lift design will work on this machine....without question. The exception would be decks made for use on tractors with vertical shaft engines. However, they too can be easily adapted to fit...very easy. The over-size 60" deck will not fit, unless you change the front axle. Here is an example of the Tach-o-Matic lift design:The Tach-o-Matic is the LIFT HARDWARE that is bolted to the top of the deck. It is very easy to mount and remove these and they are of universal design.You'd also need the MULE DRIVE that attaches to the front of the tractor.For more info, contact me outside of RS at this email address: (juct clik the link)daveoman@windstream.net Edited September 2, 2015 by daveoman1966 Share this post Link to post Share on other sites
rracioppi 2 #3 Posted September 2, 2015 Thank you Dave, I do have the Mule drive just have not re done it yet.. Share this post Link to post Share on other sites
rracioppi 2 #4 Posted September 2, 2015 Dave,Would this work if I could get the tac omatic for the top?http://southjersey.craigslist.org/grd/5193085586.html Share this post Link to post Share on other sites
PaulC 342 #5 Posted September 2, 2015 Great look tractor you have there! The deck you attached the link to will not work. You most likely want to look for a 42" side or rear discharge with the attachment setup like shown in Daves pictures. They are pretty common so I would think you could hold out for a short time and get one you could bring home and slide right under the tractor instead of having to try to do modifications to a deck for a different tractor.Do some searching on the site here and you will find tons of info. Especially like deciding between a rear or side discharge. Good luck! Share this post Link to post Share on other sites
rracioppi 2 #6 Posted September 2, 2015 Thanks Paul appreciate the response Share this post Link to post Share on other sites
daveoman1966 3,882 #7 Posted September 2, 2015 Dave,Would this work if I could get the tac omatic for the top?http://southjersey.craigslist.org/grd/5193085586.html In a word....NO. That deck is not suitable for your tractor. Share this post Link to post Share on other sites
