chorusguy 227 #1 Posted August 24, 2015 (edited) OK. As I posted last week my deck ate a double d pulley. Can't seem to find a replacement pulley. I need to get this deck up and running. I have another 48 with different style spindles in it but not sure if the spindles are any good. Sound like they need to be greased and one if them has a leaking seal. So my question if I want to replace all the spindles which ones do I use? Will it affect belt size? Deck fits c160 Edited August 24, 2015 by chorusguy added image Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,463 #2 Posted August 24, 2015 (edited) With a build date of 6327 your deck model number should be 75-48MS01.Go into the Downloads and do a search for that model number. Click on All Content and change to Files and then search and 6 will come up.Also use this manual to determine alternative spindle assemblies.http://www.wheelhorseforum.com/files/file/671-chart-spindle-id-mower-rotary-1969-1989-35-pagespdf/When you click on your model number a single page will come up with all the spindle designs on it.Garry Edited August 24, 2015 by gwest_ca Share this post Link to post Share on other sites
953 nut 68,556 #3 Posted August 25, 2015 You could post a "Wanted" ad here for the double "D" pulley, lots of them out there. Or you could take the old school route; get a ruler, flip the decks over and measure the blade height above the deck. If the two are real close to each other then it will work, may need to drill a new hole or four but it will work. Grease the one you plan to use and see how it sounds, if it is smooth turning I bet it will be fine.Good luck. Share this post Link to post Share on other sites
chorusguy 227 #4 Posted August 25, 2015 Posted two ads. No response yet. Available from toro. So will bite the bullet and get it from them. Share this post Link to post Share on other sites
