JPWH 5,320 #26 Posted September 21, 2015 My son had someone drop it off at his shop. He said it came out of a hospital bed. He gave me two actuators and two vibrator motors. I saw some as an option on new blast cabinets for 169.00 they called it a shaker.Thanks for the compliment. Share this post Link to post Share on other sites
JPWH 5,320 #27 Posted September 26, 2015 Still have a little work to do but I now have a working blast cabinet. 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,487 #28 Posted September 26, 2015 Hank, do I spy a seat backrest in there? LolGlenn 1 Share this post Link to post Share on other sites
JPWH 5,320 #29 Posted September 26, 2015 You do, and in the near future you may recognize the bracket for it. 1 Share this post Link to post Share on other sites
JPWH 5,320 #30 Posted October 17, 2015 I finally got all the bugs worked out and the cabinet is working great. I use a bucket feed siphon gun in a water jug from a water dispenser turned upside down with a hole drilled in the bottom for the tube. When the jug is empty I dump the media in a 13 gal trash can and pour the media through a sifter I made from a bucket then use a funnel to pour it back in the jug.The plexiglass lens is working good as well. I installed a metal window screen I cut down to fit into brackets about 3/4 inch below the window. I clean the screen and window while waiting for the.media to go thru the funnel into the jug. The whole process of recycling the media and cleaning window takes.about 20 minutes. I am going to add a light to each side at the front. That will eliminate shadows when working on larger items. 1 Share this post Link to post Share on other sites
