Ethan and Randies horses 65 #1 Posted August 11, 2015 heres the custom brush guard/bumper I made yesterday for my a-90 special.what do you think? 6 Share this post Link to post Share on other sites
bmsgaffer 2,071 #2 Posted August 11, 2015 I like it! I have been trying to come up with a design for one, so its good to see someone elses ideas! Share this post Link to post Share on other sites
DennisThornton 4,773 #3 Posted August 11, 2015 Need a close up of how you mounted it. Or maybe with it off... Share this post Link to post Share on other sites
DennisThornton 4,773 #4 Posted August 11, 2015 Some nice sharp bends! How'd you do that? Did you lengthen the tractor? Share this post Link to post Share on other sites
Racinbob 13,250 #5 Posted August 11, 2015 That kinda looks like one of those step bars that go into a trailer hitch receiver. Gives me some interesting thoughts......... Share this post Link to post Share on other sites
Ethan and Randies horses 65 #6 Posted August 11, 2015 it was extended 14 inches.the bends on the pipes?if so I cut them on the metal cutting bandsaw at an angle then welded then ground down heres how it is mounted that curve was cut with porta band then sanded Share this post Link to post Share on other sites
Kegler 68 #7 Posted August 12, 2015 Very nice! If you needed extra weight those could be filled with something (sand, lead, concrete) before final assembly. Share this post Link to post Share on other sites
DennisThornton 4,773 #8 Posted August 12, 2015 Cutting them first was sharp and by golly you certainly did a nice job grinding the welds on the pipes! And Kegler had a nice idea of filling them with lead! Share this post Link to post Share on other sites
Ethan and Randies horses 65 #9 Posted August 12, 2015 yea I never thought about filiing it great idea! Thanks Dennis I ground them with an angle grinder then sanded them with the belt grinder. Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted August 12, 2015 Is the tractor stretched? It looks loooong! But everything else in the background looks normal... Share this post Link to post Share on other sites
Ethan and Randies horses 65 #11 Posted August 13, 2015 yes it was stretched 14 inches I just replaced the old transaxle with a hydro tore the gears out of the old one Share this post Link to post Share on other sites
DennisThornton 4,773 #12 Posted August 13, 2015 That's pretty awesome! Who did the hood? Share this post Link to post Share on other sites
JC 1965 1,548 #13 Posted August 13, 2015 Looks great. Share this post Link to post Share on other sites
Ethan and Randies horses 65 #14 Posted August 13, 2015 we did cut it in half added a piece of sheet metal and welded it then did a lot of body putty and sanding Share this post Link to post Share on other sites
DennisThornton 4,773 #16 Posted August 14, 2015 I owned a body shop for 15 years. That's major surgery! Oh most anyone can cut up two hoods and weld them together, but dealing with the warping and having it look good is another level! Now the REAL test is also making it look good on the INSIDE! The trick there is to try to used NO filler, just hammer and dolly and a little flat filing! Tough! Time consuming!No matter what the inside looks like I'm impressed!Great job! And I'm guessing you won't need any additional weight in that bumper with the front end WAY out there! 1 Share this post Link to post Share on other sites
Ethan and Randies horses 65 #17 Posted August 14, 2015 it has three strips of sheet metal inside to keep in from bending in Share this post Link to post Share on other sites
DennisThornton 4,773 #18 Posted August 14, 2015 Does the A have the same hood as the B and C? Never had an A or B but just learned that the Bs used the same hood as the Cs so I'm thinking maybe the As as well? Share this post Link to post Share on other sites
Ethan and Randies horses 65 #19 Posted August 14, 2015 (edited) the a 90 specials were made from extra inventoy parts and most of the ones ive seen have the late 60s and early seventies hoods.I have two c 120 and they boh had difrent hoods. Edited August 14, 2015 by Ethan and Randies horses Share this post Link to post Share on other sites
Don1977 606 #20 Posted August 16, 2015 If you add 1/2" spacers behind the mount you can still use the mule drive, Share this post Link to post Share on other sites
