seven 202 #1 Posted August 7, 2015 want to put a standard clutch on my electro 12.been going on ebay and what not, have found lots ,am not sure if they will work ,its a 1 1/8 inch shaft,will like a commando 800 work .. I bought it from a guy that took off the electric one and built his own manual clutch. it probably works ok but I want restore it and make it rite.witch other models will work .or maybe stay with electric ?? Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted August 8, 2015 Hi Seven,In the simplest terms, as long as the output shaft of "any" engine is inch and an eighth, the length is minimally 2.75 inches, (some have been able to go a bit shorter), and the keyway is quarter inch, a standard wheelhorse PTO bell/assembly will fit it from the 70's thru to the end of the classic in the 90's. Some older engines had a one inch shaft but the overwhelming majority of PTO's are 1 1/8". Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #3 Posted August 8, 2015 (edited) The Commando 800 should have a 1" shaft. The 8hp Kohlers Wheel Horse used have a 1" shaft.A few of the early 10hp Kohlers Wheel Horse used have a 1" shaft.All the Briggs and Stratton engines Wheel Horse used have 1" shaft.It is the electric clutch that defines the Electro 12. Other than that it is basically a Charger 12.Garry Edited August 8, 2015 by gwest_ca Share this post Link to post Share on other sites
seven 202 #4 Posted August 8, 2015 thanks that helps a lot pretty much then just make sure its got a 1 1/8 shaft Share this post Link to post Share on other sites
boovuc 1,090 #5 Posted August 9, 2015 (edited) You got it! That's pretty much it! (As long as the motor was originally on a Wheelhorse)! Edited August 9, 2015 by boovuc Share this post Link to post Share on other sites
