JJFox 0 #1 Posted July 14, 2015 It looks like the spread on the mounting bolts on briggs, is a little on the narrow side.and 2 of the mounting bolts might fall in the middle, or on the edge of the frame rails Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #2 Posted July 14, 2015 Wheel Horse used a few. Single cylinder or twin?Garry Share this post Link to post Share on other sites
Wishin4a416 2,192 #3 Posted July 14, 2015 WH did use Briggs on some models and used a mounting plate Share this post Link to post Share on other sites
JJFox 0 #4 Posted July 14, 2015 Wheel Horse used a few. Single cylinder or twin?Garrysingle Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #5 Posted July 14, 2015 Here is one of themhttp://www.wheelhorseforum.com/files/file/3702-tractor-1982-sb-421-8-speed-da-tiplpdf/Garry Share this post Link to post Share on other sites
Don1977 605 #6 Posted July 15, 2015 I have an 18 HP Vanguard on a C-120. It's a tight fit. I'm using the original belts as I located the crank shaft at the original location. 2 Share this post Link to post Share on other sites
pfrederi 18,913 #7 Posted July 15, 2015 Most B&S engines only have sleeve bearings on the crank shaft. They cannot deal with the end thrust created by a WH PTO. Wheel Horse put an external plate and ball bearing on some of the Briggs motors they used. Share this post Link to post Share on other sites
JJFox 0 #8 Posted July 15, 2015 Most B&S engines only have sleeve bearings on the crank shaft. They cannot deal with the end thrust created by a WH PTO. Wheel Horse put an external plate and ball bearing on some of the Briggs motors they used.this one will only push snow Share this post Link to post Share on other sites
oldredrider 2,553 #9 Posted July 15, 2015 Remember; more power=more push. Compensating for low horse power by "ramming" is hard on the transmission mounting plate. Low hp requires smaller bites. 1 Share this post Link to post Share on other sites
Spareparts 85 #10 Posted July 17, 2015 My GT 2500 came with a 12 hp Briggs and as stated the bearing was out and took the block with, it has a Greyhound 13 hp. (same as the Predator) on it now. It don't work hard, just carries the grandson around the yardIt will be getting a 14hp. Kohler as soon as I get it rebuilt. Then it will be a real WH. Share this post Link to post Share on other sites
