Sprocket 48 #1 Posted July 9, 2015 I know, I know - it's a Tecumseh and that's what they do...The carb shows signs of leaking at the bowl - is is a float type carb BTW. I've replaced the hose and added a filter (made for a VW Bug). I don't think the machine likes the filter. Lots of sputtering and the adjustments are very fussy. Once it was cool it would not run with out a lot of choke so I pulled the filter and let it run long enough to put back in the barn for the night.In changing out the hose I had to pull the engine cover the has the linkage - I think it's a governor or something - see the attached pics. At one point I had to remove the links from the Fritzy (that's the arm with the holes) I though I put it all back together correctly... If someone can verify this I'd appreciate it.Whereas the carb is leaking and has say for who knows how long before I got the machine I intend to get an Oregon carb and a couple parts kits for the Tecky carb. The Oregon is to prevent downtime and the multiple kits are based on my experience from days gone by when I had a Jeep that a POS carb on it. I still have my 3 lb. hammer I used to adjust the Jeep carbs...Before I start down this frustrating road, are there any cab wizards in New England willing to help/teach me the finer arts of cab adjusting and/or rebuilding live in person? I'm willing to drive to you with the machine and lunch and beverages of choice would be on me.I've pulled a lot of the manuals etc. already and started reading up on things and now that I have my engine code I can order the right parts.Thanks for looking Share this post Link to post Share on other sites
AMC RULES 36,959 #2 Posted July 9, 2015 (edited) These new Tecumseh knock off carbs pretty much, perform flawlessly right out of the box...truly, plug & play here. Just pick your price point...but, CYA by ensuring it originates from a US based seller. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2055119.m570.l1311.R1.TR2.TRC1.A0.H1.Xtecumseh+h70+carb.TRS0&_nkw=tecumseh+h70+carburetor&_sacat=0 Edited July 10, 2015 by AMC RULES 1 Share this post Link to post Share on other sites
Sprocket 48 #3 Posted July 10, 2015 Thanks for the US based tip - I also go an email today from eBay indicating a discount until July 31 - $20 for a new one, I may get two, just need to verify part #'s Share this post Link to post Share on other sites
Sprocket 48 #4 Posted August 4, 2015 Installed the carb today - Before I changed it out I noticed the engine has a sputter to it. It was always sort of soft and subtle. With the new carb it pops, sputters and is overall choppy at idle. I pulled the plug and it was black, brushed it and checked the gap. I'll be replacing it soon.The carb is a China made unit but it seems to be set up correctly - I think the engine is tired as it bogs down on the slight incline while mowing - it still mows fine but I notice it's not full blast on the up hill.Any help with the sputters and pops is appreciated.Thanks All Share this post Link to post Share on other sites
slammer302 2,154 #5 Posted August 4, 2015 I put a after market carb on my tecky the only thing I had to do was close the low speed needle till it was almost closed and it runs great and has been all summer Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
Brian01 481 #6 Posted August 4, 2015 I have a techy, its on a Raider 10 I bought from slammer302, hh100, needs a coil...I'd sale hole mower if interested Share this post Link to post Share on other sites
Sprocket 48 #7 Posted August 5, 2015 I'm just kinda at a loss - Could it be the points or timing related? The carb is brand new, sure it may need a tweak but if it's not firing right I'm inclined to think there's more going on than too much fuel.Of course I might be over-thinking things too, which is why I ask for your helpThanks All I'm just kinda at a loss - Could it be the points or timing related? The carb is brand new, sure it may need a tweak but if it's not firing right I'm inclined to think there's more going on than too much fuel.Of course I might be over-thinking things too, which is why I ask for your helpThanks All Share this post Link to post Share on other sites
