wheelhorse101 0 #1 Posted November 14, 2008 would the gt-14 front end fit on a C series tractor and is if it does is it any stronger than the C series front end spindal wise? :hide: Share this post Link to post Share on other sites
refracman 167 #2 Posted November 14, 2008 Dan, The Gt14 front end will not fit a C. A C uses a 3/4" pivot pin whereas a GT uses a 1" pin, and it is another 1" wider or ther abouts. The GT's axels are hardened 1" with tapered roller bearings, the C's are 3/4" with caged bearings. Share this post Link to post Share on other sites
baerpath 517 #3 Posted November 15, 2008 Yes it can , you need to shave the axle to get it to fit in where the C axle was, bush the hole to accept the C axle pin and make a set of tierods for it. Yup iy's a lot stronger Duane Share this post Link to post Share on other sites
wheelhorse101 0 #4 Posted November 15, 2008 ok thanks for the advice i was just wondering because if it was an easy fit i would put it on for more strength with the loader Share this post Link to post Share on other sites
baerpath 517 #5 Posted November 15, 2008 Other than a little time no problem Also when you do this it will raise the front, to level it we used the hubs, rims and tires from the GT14 , You could go with 24 or 26 inch tires also to help level it This was done to a 520 for use in the garden for hilling clearance Duane Share this post Link to post Share on other sites
Rollerman 291 #6 Posted November 15, 2008 This was done to a 520 for use in the garden for hilling clearance Duane Duane...how about some pics of this beast? Share this post Link to post Share on other sites
pond195520032003 27 #7 Posted November 15, 2008 Duane...how about some pics of this beast? yea, really quit hiding it from us :hide: Share this post Link to post Share on other sites
htopjimmy26 3 #8 Posted November 15, 2008 I'ld just use a 520 steeraxle off of fleabay, There's a place called Joe's outdoor power that it seems is constantly parting out 520s I got a steer axle and spindles for about 150$. Good luck :hide: Share this post Link to post Share on other sites
baerpath 517 #9 Posted November 15, 2008 I lost my pictures of it in the big computor crash of 07 Next time I get to Alan's I'll take the camera with me. Duane Share this post Link to post Share on other sites
wheelhorse101 0 #10 Posted November 15, 2008 thanks for all the help guys if i could find a 520 front end i would love to get it but all i have now is the c series front end :hide: Share this post Link to post Share on other sites
