Dad&Kev 31 #1 Posted June 29, 2015 need help with wiring diagram for 71 bronco 14 with pointsless ignition . I think it must be 71 because the diagram on this site is wrong. i just don't know how this thing works. So any help would be greatly appreciated. Thank you Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #2 Posted June 30, 2015 Here is a 1971 tractor wiring diagramhttp://www.wheelhorseforum.com/files/file/5167-tractor-1971-bronco-14-wiringpdf/The Kohler manual has info on the breakerless ignition alsoHigh resolutionhttp://www.wheelhorseforum.com/files/file/3450-engine-kohler-k-91-k141-k161-k181-k241-k301-k321-sm-1972-hrpdf/Low resolutionhttp://www.wheelhorseforum.com/files/file/895-engine-kohler-k-91-k141-k161-k181-k241-k301-k321-sm-1972-lrpdf/Garry 1 Share this post Link to post Share on other sites
Dad&Kev 31 #3 Posted June 30, 2015 thank you very much. I will try to figure it out and let you know Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #4 Posted June 30, 2015 Just remember the breakerless ignition is self-powered and treated like a magneto ignition. The lone ignition wire from the engine is simply grounded to shut the engine off.DO NOT allow any battery voltage into the ignition wire as that will destroy the ignition coil.Garry Share this post Link to post Share on other sites
Dad&Kev 31 #5 Posted July 1, 2015 Thanks for the info buddy. Thats exactly what I did not understanding the system and cooked a few things. But i bought a used motor at the show a changed the bad parts and it started wright up. One more hard lesson learned! Could not have dune it with out your help thanks again. Know the boy can drive it in the tractor parade this weekend and he shore is happy witch makes all these hard lessons worth it. Share this post Link to post Share on other sites
