JOHNCONNER
Wheelhorse model 72042 won't start
JOHNCONNER
I have a 1994 Wheelhorse that won't turn over.
It mowed fine for several hours last weekend, then died like it ran out of gas.
It did this last summer, and usually the next morning it would start up.
This time, it won't turnover, backfires on starting, and exhausts a lot of white smoke...
New battery, fresh gas are not helping...
Ideas?
gwest_ca
When you say it won't turn over most of us think the starter won't work for some reason but you say it backfires and produces white smoke. I suspect you mean it won't run on it's own. White smoke is usually caused by incomplete combustion. First thing I would try is a new properly gapped spark plug. The plug number in the operators manual is wrong so make sure you have the correct one - Champion RC12YC
Service bulletin
http://www.wheelhorseforum.com/files/file/3995-toro91-preslt-lt27-spark-plug-fuel-tank-260-seriespdf/
Engine operator manual
http://www.wheelhorseforum.com/files/file/4170-engine-kohler-command-cv11-16-cv460-465-cv490-493-om-1259001pdf/
Engine service manual
http://www.wheelhorseforum.com/files/file/4169-engine-kohler-command-cv11-16-cv460-465-cv490-495-sm-tp-2339-dpdf/
Tractor service manual
http://www.wheelhorseforum.com/files/file/4598-tractor-1994-260-series-sm-492-4765pdf/
Let us know what you find.
Garry
  • Similar Content
    • Doodad
      By Doodad
      Well, I guess I've gone too far this time. I've got what I believe to be a 1974 Wheel Horse C-120 (12 HP Kohler serial7326629) that has performed nicely so far but looked a bit dirty so I had the great idea of cleanin' her up a little. Washed the tractor but the engine was dirty and I thought it would be nice to clean that up too so I sprayed some orange citrus cleaner on it and hosed it off and boy it cleaned right up and looks great...the only problem is, now it won't start...just grinds when I key the switch. I'm getting ready to take the hood off and check for spark but I'm suspicioning it's probably sucked water into the carb when I tried to pull it into the shop after washing. Anyway, that's my starting point but, before I go to far, I wanted to see what the Wizards of Wrenches have to say about what's wrong. I did get it to backfire and consider that an improvement but, no-starty, me no smarty. From the Doodad
    • mhvt
      By mhvt
      I have an old B 82 (from the 60s) that will not start. Started earlier today. I have tried everything.
      Basically, it sparks but it does not turn over. What could be happening here?
    • TailGate18
      By TailGate18
      Need help please
      Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
      I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
      The mower itself all I could find was one tag on the frame under the gas tank.
      ID # 61-08K801-05782
      Then under that 4 digits
      6337
      Has a Kohler motor info as follows
      Model-K181
      Spec- 30538
      Displ (cc)- 305
      Serial #- 2613800539
      It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
      Says it's a B-80 8 speed
      Thanks in advance
    • Chuck14025
      By Chuck14025
      12.6 volts in the battery and at the starter connection.
      10 volts on the gauge.
      Nothing when key is turned on.
    • Jpud
      By Jpud
      I have I believe is a 73 commando 800 8hp kohler k181s put a new switch on it due to starter sticking on and got a new starter and completely charged the battery and new solenoid has power to the battery side of solenoid but not starter side but will turn over if jumped has no power going to the switch. Wondering if anyone had this problem before
