608KEB
520H oil sending unit
608KEB
I have a 1994 520H P220G. I was wondering where I could find a oil sending unit and what the parts number is.
Edited by 608KEB
gwest_ca
Here is the IPL and the oil switch is on page 32. Part number NN10824 is an Onan part number and no longer available from Toro. Onan parts suppliers should still have it.
http://www.wheelhorseforum.com/files/file/3813-tractor-1994-520-h-da-om-ipl-wiringpdf/
Garry
608KEB
I printed the parts manual. It's now PN #309-606 superseding NN10824. $17.00 from Jack's Small Engines.
608KEB
Is there a way to test the oil sending unit? Just took it out.
gwest_ca
From the Demystification Guide
Garry
608KEB
This is the new oil sending unit I got. It does not have 2 brackets for the wires to attach to. Suggestions?? The other picture is what is on the onan now.
Edited by 608KEB
WNYPCRepair
Are there two wires that connect to the old one? I only see one
gwest_ca
Different part number also. I recall many switches listed in an Onan parts list depending on what you wanted it to do. Did you order the NN10824?
Garry
WNYPCRepair
Garry
Bag says NN10813
608KEB
I think the box has the right parts number. The bag is the wrong parts number along with the switch. I've been waiting over 7 weeks to get this part. Would somebody  have any ideas where else to try to source this switch?
Edited by 608KEB
608KEB
Would somebody know of another oil sending unit that would work? A different parts #?
608KEB
I got this today 309-606. Will this work it does not have a ground connector for the hour meter. Will it operate the oil light correctly. Will it open and close at 5 psi + or - 2 psi? I don't know what the numbers mean on the side of the switch. I can ground my hour meter to the engine. I hooked it up and the oil senor light did nothing. I'm starting to think I have a bad connection somewhere.
Edited by 608KEB
  • Similar Content
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
