Live4outdoors 151 #1 Posted June 18, 2015 I have a 876 that loves to mark her territory all over my barn floor, I'm thinking I need to fix it but it runs and drives great and hydros always scare me, any suggestions, how hard is it to change gaskets in them? Any suggestions of where to get gaskets and what not to do? Thanks all in advance! Share this post Link to post Share on other sites
squonk 46,891 #2 Posted June 18, 2015 Contact daveoman. He has worked on hydros 1 Share this post Link to post Share on other sites
Live4outdoors 151 #3 Posted June 18, 2015 Thanks will try to send him a message... Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted June 19, 2015 Usually just o ring replacement behind the nylon thingy. One of them is still available...substitution may he required for the other. Share this post Link to post Share on other sites
pfrederi 20,677 #5 Posted June 19, 2015 Where is she leaking from...could just be axle seals..... Share this post Link to post Share on other sites
Live4outdoors 151 #6 Posted June 19, 2015 No unfortunately the whole underside is soaked, I'm sure it's at the main seal on the two halves, need to pressure wash it to be absolutely sure though...LOL what's the nylon thingy?? Share this post Link to post Share on other sites
oldredrider 2,553 #7 Posted June 19, 2015 Technically, it's the cam plate. The shaft it operates on the front of the motor has two o rings that fail over time. If that is the area where it is leaking, you found the problem. Share this post Link to post Share on other sites
pfrederi 20,677 #8 Posted June 20, 2015 O rings are #52 and 55 both NLA but you should be able to match them up at a good hardware store or hydro repair place. The gasket between the hydro gear and the transaxle is also NLA... Gasket material and a scalpel 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,282 #9 Posted June 20, 2015 Don't know which gasket you need but5955 Sundstrand hydro pump gasket nla - 102759 gasket should workGarry Share this post Link to post Share on other sites
Live4outdoors 151 #10 Posted June 23, 2015 Thanks guys, will have to wait until a couple weekends now with the show then the 4th, thought I would've got to it over weekend and wife had different plans. It would be wonderful if just o rings! That at gasket number for any toro dealer? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,282 #11 Posted June 23, 2015 Here is a photo of both gasketshttp://www.wheelhorseforum.com/topic/52202-c-120-hydro-gasket/#comment-481689Yes - any Toro dealer will have or can gethttp://www.partstree.com/parts/search/parts/?searchTerm=102759Garry Share this post Link to post Share on other sites
