608KEB
Picked this up a few weeks ago.
JERSEYHAWG /  Glenn
Looks healthy and nice. Hours? Just curious.........pedal conversion to, a bonus. Best of luck.
Glenn
shallowwatersailor
Nice looking 520-H! Nice compression readings on that Onan.
muz123
Nice save!!
608KEB
The hour meter reads 226. It doesn't work right now. when I replace the oil sensor it should work. The meters ground runs through  the sensor. The foot pedal is homemade. It works good.
I'll post some better pics.
Edited by 608KEB
AMC RULES
Thing looks...
sweet.
 :bow-blue:
papaglide
Now THAT is a nice looking tractor!
608KEB
A few more pictures. The light was not that great with the first set of pictures. I have not had a chance to put a deck on it yet.  I really want to try the foot pedal. I have one of Matt's pedals on my 520H with snowthrower. I'll try to post some better pictures of the pedal and how its fabricated.
608KEB
A couple pictures of the 520H
  • Like 4
muz123
You have a very nice 520H!! Its even better with low hours!!
JPWH
Very nice tractor!!  Just getting broke in good.
608KEB
Last summer I decarboned the heads, Pistons and adjusted  the valves. I've noticed that after it's hot and running a while that I can hear a valve ticking. I know that I set the valves correct. I triple checked it when I did it. Any ideas on why it's ticking?  It's not real loud. But I can definitely  hear it compared to running my other 520H's.
cheesegrader
Ooooh, that's nice!
How did you get it before me?
Looks garage kept.
Love the foot pedal.
Don't know about that fuel filter, though.
Wishin4a416
Nice one! I some how missed the post last year.
WVHillbilly520H
Idk ,but I think I hear the same thing in 2  of mine, do you think the carbon build up sorta cushions/masks the ticking before cleaning/decarboning and adjusting of the valves, or is it an exhaust leak (like on a car exhaust manifold leak sounds like a valve tick usually cold but sometimes hotter it gets worse the tick),Jeff.
jdleach
Stuck hydraulic lifter? :rolleyes:
608KEB
I put new gaskets on the exhaust. When I decarboned  the heads and pistons. I also used the copper colored gasket spray. If the valve is sticking. How do I resolve the problem?  The ticking gets louder when the motor is hot. I'll do some investigating. It could be a exhaust leak.:blink:
Edited by 608KEB
  • Similar Content
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
