Fordiesel69 272 #1 Posted June 8, 2015 I can buy car parts cheaper than what toro charges for a tie rod. Any option out there for either a complete tie rod or end that is more affordable? Share this post Link to post Share on other sites
Racinbob 13,040 #2 Posted June 8, 2015 I've used these quite a few times. Less than $10 a pair. 1 Share this post Link to post Share on other sites
Don1977 606 #3 Posted June 8, 2015 I did this 26 years ago. Still works great. 4 Share this post Link to post Share on other sites
Fordiesel69 272 #4 Posted June 8, 2015 I've used these quite a few times. Less than $10 a pair. Where did you buy these? Share this post Link to post Share on other sites
bmsgaffer 2,071 #5 Posted June 8, 2015 One of our vendors is making and selling good quality tie rods... Many people have been very happy with his parts.http://www.wheelhorseforum.com/forum/141-wheelhorseman1000s-hitches-brackets-parts-and-more/ Share this post Link to post Share on other sites
953 nut 67,382 #6 Posted June 8, 2015 Check out Agri-supply part # 45-111, $ 4.49 each. Share this post Link to post Share on other sites
RedRanger 1,470 #7 Posted June 8, 2015 I've used these quite a few times. Less than $10 a pair. What do you use between them? Share this post Link to post Share on other sites
Racinbob 13,040 #8 Posted June 8, 2015 For a Suburban drag link I used 3/8"-24 threaded rod with a piece of 1/2" OD steel tube the correct length over it. There's no need for adjustment in this application. For an adjustable tie rod you'd want to use a jam nut. Share this post Link to post Share on other sites
Racinbob 13,040 #9 Posted June 8, 2015 I've used these quite a few times. Less than $10 a pair. Where did you buy these? I got those at Ace Hardware. There's a gazillion of them on Ebay cheaper but I was in a hurry. Tractor Supply also has them as well as many other places. Share this post Link to post Share on other sites
squonk 47,375 #10 Posted June 8, 2015 I did what don did on my 704 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #11 Posted June 8, 2015 If you have a needle for your grease gun you can slip it under the rubber for a shot of lube also. Sure eliminates the rust and wear.Garry Share this post Link to post Share on other sites
KC9KAS 4,746 #12 Posted June 9, 2015 I've used these quite a few times. Less than $10 a pair. Where did you buy these? I got those at Ace Hardware. There's a gazillion of them on Ebay cheaper but I was in a hurry. Tractor Supply also has them as well as many other places. You can see these on the web...McMaster Carr...many different types....Left and right hand threaded if you need them that way. Share this post Link to post Share on other sites
