GlenPettit 1,714 #1 Posted June 5, 2015 Way past due tilling our garden, and several neighbor's too.My C-160 will start fine, sounds and runs excellent; it will run and I can till for 2 minutes, then she quits, abruptly.Fresh gas, new gas filter, screen in tank was cleaned, wiped inside of carb bowl, air filter very clean, fresh oil.Will restart right away, but only run 30 seconds, then next time 10 seconds; if I let it set an hour, it will start andrun agian for 2 minutes . . . just enough time to till just one 40' roll . . . then I wait an hour, repeat, just one roll.This tractor has over 500# of weight in and on the four tires, plus tiller, very hard to move when 'dead'. Been trying for a month now, help, help, help. Please, suggestions . . . ? Glen Pettit Share this post Link to post Share on other sites
rmaynard 14,932 #2 Posted June 5, 2015 Just a guess, but have you tried loosening the gas tank cap to see if the vent is clogged and you are pulling a vacuum? 3 Share this post Link to post Share on other sites
Don1977 604 #3 Posted June 5, 2015 Check the fuel pump! 1 Share this post Link to post Share on other sites
Shuboxlover 474 #4 Posted June 5, 2015 Also check you ignition system (points, condenser, coil) 1 Share this post Link to post Share on other sites
nylyon-(Admin) 7,122 #5 Posted June 5, 2015 If it's restarting right away, I lean towards ignition, coil / condenser. Condenser is a under rated item, I once had a 700+HP 440+6 act like a Yugo because of a failed condenser! 1 Share this post Link to post Share on other sites
daveoman1966 3,628 #6 Posted June 5, 2015 The symptoms you post are typical of a failed condenser, when it gets just a little bit hot. Replace it ...... 2 Share this post Link to post Share on other sites
squonk 39,021 #7 Posted June 5, 2015 Can you just start it up and run it with the hood open and then the engine dies? If so you can get a nice cheap inline spark tester from Napa. Start it up and watch the spark indicator. When it quits and the spark goes away, then you know it's ignition/ Electrical and not fuel. 2 Share this post Link to post Share on other sites
buckrancher 2,677 #8 Posted June 5, 2015 easy to change the condenser it's on the out side of the motor 1 Share this post Link to post Share on other sites
GlenPettit 1,714 #9 Posted June 5, 2015 Got and installed a new Kohler condenser (#230722-S, $22), but have not seen any improvement, now the C-160 will not run more than about 30 seconds before quitting, with or without the load/tiller. Double checked and cleaned all related systems I can think of, again. Something I forgot to mention is that the battery is dead and I have to jump it from my 312 each time to start it. Any chance the battery could be a factor, –– will get & install a new battery tomorrow. Again, any help, suggestions and advice is very much appreciated. Glen Share this post Link to post Share on other sites
squonk 39,021 #10 Posted June 5, 2015 Yes it could be related. I'm not sure with Kohler charging systems but on a lot of cars, if the battery voltage is too low, the alternator will not activate. 1 Share this post Link to post Share on other sites
rmaynard 14,932 #11 Posted June 5, 2015 You cannot run that tractor without a battery. If the battery is dead, the engine will stop. Try another battery. 1 Share this post Link to post Share on other sites
Racinbob 10,390 #12 Posted June 5, 2015 Yup, you found the problem. I'd suggest checking the charging system when you install the new battery. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,967 #13 Posted June 6, 2015 Not sure about yours Glenn but the three prong regulators have to have 12 volts on the center post to putcharging voltage back to the battery. 1 Share this post Link to post Share on other sites
GlenPettit 1,714 #14 Posted June 7, 2015 OMG ! Everything works perfect now, since I installed a new battery,why did I wait so long (just trying to be cheap I guess), all I needed wasthis new battery to make everything work perfect, like it should.Got my garden tilled and 3 others all today, and I've been down since last summer.I sure got a whole lot smarter now, thanks to everyone.Glen 2 Share this post Link to post Share on other sites
wrightorchid 261 #15 Posted June 7, 2015 I love it when a plan comes together. The knowledge on this forum is amazing. The best part is that even though folks are all over the country, it is like having a nice neighbor that can help. 1 Share this post Link to post Share on other sites
