SteveinMo 0 #1 Posted June 4, 2015 I have a 10 HP Kohler. md. # 9094873. It is on a 1973 unit looks original. Cranks over well and I smell gas. No spark at the plug. Ran great last year now nothing. The coil has the external condenser. Where do I start looking for the voltage loss or read what voltage. Thanks for the help. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted June 4, 2015 Try cleaning up the points first. Probably just oxidation. Share this post Link to post Share on other sites
Shuboxlover 481 #3 Posted June 4, 2015 Turn your key on and see if you have 12V to the positive side of the coil, if you do...then follow Paul's advice. If not, then it could be anything from a bad switch, bad wire, faulty safety switch etc.. Share this post Link to post Share on other sites
953 nut 62,028 #4 Posted June 4, 2015 I would start with a new Champion H-10 spark plug. Share this post Link to post Share on other sites
pfrederi 18,912 #5 Posted June 4, 2015 If you want a new plug I would try anything but a Champion... Auto lite 216 works well for me. I have had too many Champions fail when under compression, Share this post Link to post Share on other sites
Buckshot 1 15 #6 Posted June 8, 2015 If you want a new plug I would try anything but a Champion... Auto lite 216 works well for me. I have had too many Champions fail when under compression, Amen to the above post. I gave up on the H10's years ago. Nothing but 216's for my K series Kohlers. Share this post Link to post Share on other sites
