tommyg
What are these?
tommyg
I'm replacing the O-rings between the manifold and hydro pump on my D-180. I've got a NOS seal kit. In it are 7 O-rings. There are 3 larger backer rings and two matching O rings. I'm assuming the two larger O rings and associated backer rings belong to the high pressure ports. The two smaller O rings belong to the smaller low pressure ports. I don't believe these require the backer rings. I also have one metal bound O ring the size of the smaller O rings. My questions are... Why do I have one extra high pressure O ring and what the heck is that metal bound O ring for?
Edited by tommyg
wheeledhorseman
Having just reassembled the hydro system on my D-200 I can offer the following. At the pump end you need two smaller O-rings for the low pressure, two larger O-rings with backer rings for the high pressure.
Having separated the pump and motor from a tandem unit from a C series to use as replacements for my D, I'm pretty sure the kit you have can be used to mate a pump to motor in tandem configuration when you'd need the copper / metal bound washer (it seals one of the allen key bolts that holds the motor casing to the pump internally. The extra backup ring you have seals the faces of the pump and motor where that bolt passes through. You'd need the extra backup ring for the motor end - manifold connection on a D but the copper / metal bound washer is needed for direct pump - motor connection only.
I'm sure someone else will correct me if I'm wrong.
Andy
tommyg
That sounds like a fair answer. If I'm just replacing the pump end seals, it seems all I would need would be the two larger high pressure O rings, the two backer rings and the two smaller low pressure O rings. Sound right?
wheeledhorseman
That's what I used.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
