bubbacola 8 #1 Posted May 25, 2015 I have a 416 wheel horse ... When I bought it it ran half choke full throttle .. Had carb rebuild and new battery last fall for using it for snow throwing.. Ran ok still had to run with a little less then half choke to keep running but ran ok to do snow removal.. Spring time I got thrower off to use for pulling sprayer around.. My surprise it ran with out choke but was hard to start.. After running for 15 min. It started running rough like it was starting to run out of gas ( full tank) it ran like that a little longer a stopped.. Tried to restart but battery was dead so I grab one of my other tractors and jumped it.. It stared right up and ran good about half way back to shed when start to run bad again and died as I got back to shed.. Charged battery for an hour and started it again started right up and ran good for about 15 minutes and again. Sounds like running out of gas so I put battery charger back on and it cleans right up runs good again... Hmmm put volt meter On with charger off started at 12.58 in 5 minute it was 12.32 and starting to sound like it running out of gas. Plug charger in and it clears up.. Is it a charging problem or fuel problem or something else.. Thanks Bernie Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted May 26, 2015 The first thing I would do is look at the fuse block on your tractor. Look for pitted, thinned or burned contacts on the fuses. Next.......check your ground and make sure your battery terminal posts are clean. Make sure your connections everywhere on the tractor are not loose and for extra measure, take them off and touch them up with an emery board and reconnect. Spray your connectors with contact cleaner. Lets eliminate the simple stuff first. You have a battery ignition so if it isn't charging correctly, you will get weak spark then no spark at all. Do the above and check back with us, Bubba. 1 Share this post Link to post Share on other sites
wheeledhorseman 579 #3 Posted May 26, 2015 Check out a thread I did a couple of years back http://www.wheelhorseforum.com/topic/39682-hunting-season-over-for-my-onan/#comment-359941There are similarities with the symptoms I was suffering with a 16HP Onan.Andy Share this post Link to post Share on other sites
bubbacola 8 #4 Posted May 26, 2015 Boo vac... That is what I'm going to do today pull all connections And clean .. I was thinking because of voltage drop it wasbattery charging system bad but a friend pointed out maybe it's dropping because it's charged .... Horseman..... We did a vacuum check before we pull the carburetor the first time. when I got the tractor it had to run full throttle with choke. After rebuild it would run any speed but some choke ( this was in winter blowing snow) now warn weather runs great no choke hard to start dies after 15/20 minutes of running like its out of gas starts right back up when charger is put on... I have replaced gas filter loosed gas cap when it starts acting up. new plugs, wires but not the coil yet.. Thank guys for your input. I will retest for vacuum leak with propane this time and clean all connections and post Results thanks again. Bernie Share this post Link to post Share on other sites
bubbacola 8 #5 Posted May 31, 2015 Well after any hours of cleaning connections running the motor testing with volt meter we found it not to be charging because the guy who I got it from had done a little wiring ... On voltage regulater had red wire in center , two white wired on one side and a gray wire on the other... Wiring diagram shows a white wire on the two ends so we did that and BOOM it runs great. Charges 14.42 now starts right up and purrs like a kitten... Now if I can only find were the Gray wire goes Share this post Link to post Share on other sites
ericj 1,580 #6 Posted May 31, 2015 gray wire is for the tac, not used for the 416eric j Share this post Link to post Share on other sites
bubbacola 8 #7 Posted June 1, 2015 Erich thank you we thought it was for tac so we didn't hook it up again.. This tractor runs really good now . I was ready to part it out but I'll keep it now Share this post Link to post Share on other sites
boovuc 1,090 #8 Posted June 1, 2015 Way to go! Glad it's running well again! Share this post Link to post Share on other sites
