Shuboxlover 481 #1 Posted May 24, 2015 Quick question guys.Does the magnum 8 (from a 308-8) have a 1 1/8" crankshaft, or is it 1"Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #2 Posted May 24, 2015 Can't find an original parts list but the online lists show the 2 different pto inner races so have to assume the 8hp still used the 1" crank.Garry Share this post Link to post Share on other sites
Shuboxlover 481 #3 Posted May 24, 2015 That's what I would have thought...but....If you look at the toro master parts viewer, it lists the 7443 pulley (which is the same as a 520) but I thought for sure it would have used a 1" crank instead of 1 1/8". Can anyone confirm this??? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #4 Posted May 24, 2015 Look down the list and you will see two other engine pulleys as well.#101875 - 4" OD x 1" ID for manual transmission#7466 - 4" OD x 1-1/8" ID for manual transmissionGarry Share this post Link to post Share on other sites
Shuboxlover 481 #5 Posted May 24, 2015 Well that's even more confusing, how do I know which one it's supposed to be??? Share this post Link to post Share on other sites
wallfish 18,614 #6 Posted May 24, 2015 Measure the crankshaft or is this for an engine you don't have in hand? Share this post Link to post Share on other sites
Shuboxlover 481 #7 Posted May 25, 2015 I Don't have access to the engine. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #8 Posted May 25, 2015 Only an original parts list will indicate what pulley was used on each engine and we do not have one. Thanks to forums like this we have learned the pulley dimensions and that the 1" pto shafts were used on the Briggs and Stratton engines, the 8hp Kohler engines and a very few early 10hp models in the mid 1960's. Looking at the online parts lists one can see which engines that list applies to. The fact that the 1" pulley is listed means one of those engines used it and the only candidate is the 8hp Kohler based on what we have learned.Garry Share this post Link to post Share on other sites
Shuboxlover 481 #9 Posted May 25, 2015 Thanks Garry!!!! Share this post Link to post Share on other sites
can whlvr 994 #10 Posted June 1, 2015 sorry didn't see this post earlier but the 308 definatly used the 1 inch crank,i have one I bought fron new and have since put a Honda on her and it is 1 inch shaft,also used the riser plate Share this post Link to post Share on other sites
