John Galt
Has anyone done a gt14 diesel swap
John Galt
I'm kicking around the idea of swapping my kohler 321 k 14 horse power motor for a diesel engine. Haven't figured out why my motor won't fire up. My thinking is if I have to drop a few hundred bucks on my old kohler engine, it might just be better to get a new one without spark problems.  I was wondering if anyone else has done that swap in a gt14 and open to any thoughts on the subject. It is a working tractor. Or it use to be.
Stigian
I have never tried it but a diesel powered Gt-14 sounds a great idea :thumbs:
callum12
a diesel GT14 would be amazing! there is a guy on youtube that has made a diesel sears. he used a Chinese clone engine though.
If i was to do it I would go all out and use either a Lister LT1 or LD1 (lister later became petter). they also the the Lister LT1 in a 2 6 cylinder format as well. I reckon if you could squeeze a 3 cylinder in there it would become my favourite wheel horse of all time as it would sound like a full size vintage tractor!
here is the 3 cylinder, might be  bit big though:
lister-petter-3-cylinder-eng70ece144-1_z
the newer  LT1 stater motor can be installed on these:
diesel-engine-single-drum-air-cooled-577
the older LD1 not sure about starter motors:
I might have got a bit carried away here! :) sorry!
callum
SALTYWRIGHT
 I HAVE DONE A 417-8 AND A 1054 TO DIESEL. I HAVE A GT-14 AND WILL DO THAT NEXT.
John Galt
Saltywright, What diesel engine did you use? What differences in performance do you notice? With the problems of ethanol and gas becoming stale it might be a better alternative if it's cost effective. I need my tractors to work.
SALTYWRIGHT
HI.....I USED THE CHINA KNOCK OFF. A 10 H/P IN THE 417-8. A 6 H/P IN THE 1054. I WILL PUT A 10 H/P IN THE GT-14. I NEVER FELT I NEEDED MORE POWER. IN 1974 I PUT A 6 CYL. DIESEL IN MY CORVETTE BECAUSE OF THE GAS SHORTAGE. THE LAST BOAT I WAS CAPT. ON HAD 2 860 H/P DIESELS.     RUSS
callum12
thats what this guy used on youtube with his sears, i think the diesels run slower so to produce 10hp they actually make more torque? (something like that anyway)
callum
953 nut
​:banana-gotpics:    have you posted these?
SALTYWRIGHT
MY DIESELS RUN 3600 R.P.M.
shallowwatersailor
On Sunday I installed a Tiny Tach Diesel Tachometer/Hour Meter on my DC-105. This is the new version that has a flash memory and is connected to tractor's battery instead of the old internal battery with a five year life span. I can now install an ammeter in place of the old hour meter.
I had originally bought it to install on the 523Dxi but realized that the Carol Stream 10 hp diesel uses an injector pump as well. The inducer (6 mm size) is installed on a straight portion of the fuel line. Because I am still breaking the engine in, I was curious as to the rpm I have been using. The manual recommends to not run at high rpm until twenty hours of use. It has 6-1/2 hrs on the engine so far. Because it counts the pulses with the transducer, I can't add the other six hours like a gas version hour meter though. While breaking the engine in, I try to make three passes up and down my street which take approximately 1/2 hour! Pretty boring at this point and wish there was a youngster around to do it. My dog has trouble with the clutch and can only manage a hydro. :ychain:
DSCN3164.thumb.JPG.ec0847f9102ceeb16c2cfDSCN3158.thumb.JPG.a272160d78016bafe0ed2
Edited by shallowwatersailor
steamdriven23
So has anyone completed a diesel swap in the GT14?  I too have been kicking that idea around.
  • Similar Content
    • Rob R
      By Rob R
      I finally broke something serious on my GT14 the Lift arm that is attach (by chain) to the plow snapped off at the receiver arm top which is attached to the Hydro cylinder on the bottom. It appears the broken arm was welded there (see pics) my big question is how do get the "H" arm which is mounted on each side of the tractor by the steel plates the go up from the tractor frame out. I took off the four mounting bolts for it but it is tightly fit in aforementioned side plates I can move it up and down but cannot get it out. Is it relatively easy to remove one of the side plates and if yes which side is the easiest the pedal side left side (from the back) or the right side (from the back). Has anyone from the square experienced this problem, does anyone have this lift assembly. Any and all comments welcomed. p.s. I have used this beast for 10 years with zero major issues guess the stress of the lifting finally got to the arm which obviously is under tremendous pressure......Rob
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
