snorky 29 3 #1 Posted May 19, 2015 Hello all ...please can you help I have split a commando transmission for reasons I won't go into .....can anyone guide me on how the 2 small ball bearings that keep the gear selection in place are re inserted. ..it looks difficult Neil Share this post Link to post Share on other sites
Save Old Iron 1,573 #2 Posted May 19, 2015 (edited) ..it looks difficult a little - yes.insert the innermost shift roddrop in a detent ball, the shift stop spring and the shift pinmove the shift rod until the ball, spring and pin are all shifted into a detent in the 1st shift rod.position the trans case so the shift spring is pointing upward and drop the 2nd detent ball onto the springnow the challenging part - and very few get this right the first timeinsert a long allen wrench thru the outer access hole in the trans case, and compress the detent / spring / pin combowhile pushing down on the 2nd detent ball with the allen wrench, slide the 2nd shifter linkage into the trans case so the leading edge of the shift linkage slides over part of the 2nd detent ball - capturing the detent ball under the shift rodonce the detent is "captured" under the shift linkage, remove the allen wrench and slide the 2nd shift linkage completely into the case until the 2nd detent ball clicks into the detent on the 2nd shift rod.if you are successful - great. If not there will be weeping and gnashing of teeth. If the insertion of the 2nd shift rod does not properly capture the 2nd detent ball, the stiff spring pressure may cause the spring and ball to fly across the room. It may be helpful to keep a rag on top of the case as you remove the allen wrench. This will help prevent the spring and ball from jumping out of the case and rolling underneath your workbench - never to bee seen again. Edited May 19, 2015 by Save Old Iron 3 Share this post Link to post Share on other sites
snorky 29 3 #3 Posted May 19, 2015 Thanks save old iron...I will give it a go and let you know the results neil Share this post Link to post Share on other sites
snorky 29 3 #4 Posted May 19, 2015 Do I have to remove the blanking plug from the outer casing. .neil Share this post Link to post Share on other sites
Save Old Iron 1,573 #5 Posted May 19, 2015 yes , drive a wood screw into the plug and pull it out Share this post Link to post Share on other sites
buckrancher 2,695 #6 Posted May 19, 2015 http://www.wheelhorseforum.com/topic/9468-brians-854-complete-rebuild/?page=2 Share this post Link to post Share on other sites
pfrederi 19,940 #7 Posted May 19, 2015 The balls are 1/4" I bought a hundred from McMaster. I refuse to spend my life trying to find them when they fly out and roll away 1 Share this post Link to post Share on other sites
snorky 29 3 #8 Posted May 19, 2015 (edited) Thanks for the info Neil Edited May 19, 2015 by snorky 29 Share this post Link to post Share on other sites
snorky 29 3 #9 Posted May 19, 2015 thanks all ...I was lucky and got it together first go, I will post a few pictures as I go along with my project thanks againNeil (in the UK) Share this post Link to post Share on other sites
