Welsh Wheelhorses 8 #1 Posted May 9, 2015 Hello does anyone know the measurements for the bearings im the sundstrand 90-1136 in my 1974 c160? I would like to be able to get them from my local bearing supplier. It's the ones in the side of the transaxle case the with the closed ends. I understand some are longer than others? Thanks for your help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,164 #2 Posted May 9, 2015 Was going to try and look them up but discovered the 90-1136 was used in the 12hp and 14 hp models. The C-160 shows as using 90-1140. Has the transmission been changed or are you getting the 90-1140 off the ID plate? Garry Share this post Link to post Share on other sites
Welsh Wheelhorses 8 #3 Posted May 10, 2015 Here is the id plate. I do not know the history of the c160 because I got it out of a bramble patch! As you can see it was a bit worse for wear when I got it. I am slowly pulling it in to shape now but it's taking awhile. 2 Share this post Link to post Share on other sites
Racinbob 12,896 #4 Posted May 10, 2015 Wow! Most folks would have considered that a parts machine but you decided to save her. Outstanding! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,164 #5 Posted May 10, 2015 Here is what I think the needle bearings are from my notes WH 1526 axle bearing for 1-1/8" axles Torrington B-1816 (1-1/8" x 1-3/8" x 1" deep open) WH 1528 axle bearing for 1" axles Torrington B-1616 (1" x 1-1/4" x 1" deep open) WH 8049 replaced by WH 5960 Torrington M-16101 (1" x 1-1/4" x 5/8" deep closed) 1 required WH 1532 Torrington M-16121 (1" x 1-1/4" x 3/4" deep closed) 3 required Seems like 1974 they used 2 different transaxle models as you will see on the 1st pages of this parts list Garry Share this post Link to post Share on other sites
pfrederi 20,285 #6 Posted May 10, 2015 Try some paint remover on the outside end of the bearings. You can usually see the bearing number (not the WH part#) so you can be sure. Share this post Link to post Share on other sites
Welsh Wheelhorses 8 #7 Posted May 10, 2015 Thank you for the replys when the restoration is complete I will post all the photos I have taken as I have gone along. Thomas Share this post Link to post Share on other sites
