"D"- Man 827 #26 Posted January 18, 2017 (edited) Thanks steelman, this frame is the best part of anything I have ever had powder coated. Here are some more pics of the assembly of the front axle through the spindles. (I realize this may be a bit redundant, however; I am showing the Black frame edition this time.) 1.) Front Axle 2.) Grease zirks (2 pics) 3.) Edge Trim {non OEM, just added for protection} (2 pics) 4.) Pivot Pin (2 pics) 5.) Washers (2 pics) 6.) Bolts and Lock Nuts 7.) Greased the center zirk here 8.) Greased the axle/spindle opening (2 pics) 9.) Upper Thrust Washer (2 pics) 10.) Greased 11.) Thrust Needle Bearing 12.) Greased 13.) Lower Thrust Washer (2 pics) 14.) Greased 15.) Left Spindle (2 pics) 16.) Installed 17.) "E"-Clip 18.) Installed 19.) Ditto 8 through 18 for the Right Side {not shown} 20.) Greased the spindle zirks here 21.) Front axle complete Next, are the Tie Rods and Steering Bell-Crank. Edited January 23, 2017 by "D"- Man 1 Share this post Link to post Share on other sites
"D"- Man 827 #27 Posted January 20, 2017 (edited) 1.) Steering Bell-Crank {this is an extended height bell-crank} (2 pics) 2.) Grease Zirk 3.) Upper washer (non OEM) {I ground a hardened washer down to fit inside of the I.D. of the bigger washer, because I was unable to find a hardened washer with the correct ID/OD. that this required} 4.) Bushing Surround Washer (non OEM) (2 pics) {this is required in order to allow the bell-crank to pivot freely} 5.) Bushing Extension (non OEM) 6.) Bushing 7.) Bell-Crank positioned on upper washer 8.) Lower Washer (non OEM) {I ground a hardened washer down to fit inside of the I.D. of the bigger washer, because I was unable to find a hardened washer with the correct O.D/I.D. that this required} 9.) Bolt {This is longer than OEM} 10.) Lock Nut (shown mounted in last 2 pics) I greased the bell- crank here 11.) Tie Rod End (non OEM) Metric 12.) I attached this to the bell-crank, however; I failed to take a picture 13.) Tie Rod (Bored out and tapped for the metric threads) 14.) Tie Rod/ Tie Rod End assembly 15.) Tie Rod End/ Tie Rod/ Tie Rod End mounted bell-crank to right spindle (notice the Tie Rod End that mounts to the spindle has the spacer) 16.) Ditto for the left side 17.) Drag Link Tie Rod End mounted to the Bell-crank {P.S. Next is the front wheels and tires} Edited January 21, 2017 by "D"- Man 2 Share this post Link to post Share on other sites
Unclegdog 10 #28 Posted January 27, 2017 Wow! That's very nice! I love the D series. 1 Share this post Link to post Share on other sites
"D"- Man 827 #29 Posted January 27, 2017 1 hour ago, Unclegdog said: Wow! That's very nice! I love the D series. Thanks uncle, I was amazed how nice the powder coating turned out, I am only able to rattle can the rest, but; I am trying to do my best. The next post may be awhile as one of the front tires is not holding air and I need to sort that out. 1 Share this post Link to post Share on other sites
"D"- Man 827 #30 Posted February 27, 2017 (edited) Had an issue with a leak in one of the front tires, after sanding the bead area on the rim, repainting, and reassembly of the tire to the wheel, I tested it in water and found out that the leak was due to a faulty core in the valve stem. I also was able to purchase a couple of the #104396 Ball Flange bearings {New Old Stock} but had already taken pics with the used before they arrived.48.) Left Spindle49.) Left Inner Shim .05050.) Left Inner Shim .01551.) Left Wheel Assembly52.) Grease Zirk53.) Zirk Installed54.) Valve Stem {Non O.E.M.} I have C3 Corvette Flags valve stem caps I will be using instead of the plain chrome shown55.) Valve Assembly Installed56.) N.O.S. Ball Flange bearings57.) Bearings Installed58.) Tire Installed on Wheel59.) Wheel Tire Assembly on Spindle60.) Left Outer Shim .01561.) Left Outer Shim .05062.) Left Thick Washer63.) Nyloc Hex Bolt {Non O.E.M.} Greased Bearings64.) Hub Cap {New Old Stock}65 - 81.) Ditto for Right Side You can click on pics to enlargeNext update, (if any - not really noticing much interest in these updates, compared to the amount of time, effort and expense required to produce a resto-mod of this magnitude} may be awhile as I have quite a bit of sorting to do with the hydro transaxle and dual ag tires / wheels before I can proceed. Edited February 27, 2017 by "D"- Man 4 Share this post Link to post Share on other sites
bmsgaffer 2,071 #31 Posted February 27, 2017 (edited) Oh the interest is there! No worries. I know on threads like these, the long term projects, people sit back and watch. Especially since we have never gotten a big picture idea here, all the updates are just little parts and pieces. I think most people are just lying in wait of the reveal... Or a least a bit more of a "zoom out" so to speak. I know I religiously check in, but I have not much to say until i get an idea of what is all going on here! But either way, I am looking forward to what is to come! Just as a last note, replies aren't always what shows the interest level, make sure to check out your view count... I see over 2100 views here! Edited February 27, 2017 by bmsgaffer 5 Share this post Link to post Share on other sites
"D"- Man 827 #32 Posted March 6, 2017 Took some pics of the right side front wheel / tire assembly with N.O.S. bearings installed and also both wheels / tires on front.Next the hydro trans-axle and motor {hydro}. 4 Share this post Link to post Share on other sites
19richie66 17,932 #33 Posted March 7, 2017 Going to look SWEET! Great work and attention to detail. Keep at it Mark. 1 Share this post Link to post Share on other sites
"D"- Man 827 #34 Posted March 7, 2017 Thanks Richie, I am keeping at it, this next part, the transaxle, will be the most challenging, as I have never rebuilt a hydro before. Share this post Link to post Share on other sites
"D"- Man 827 #35 Posted March 13, 2017 (edited) Just a bit of an update, as I have began the reassembly of the transaxle.82.) Right-hand Transaxle Case83.) R.H. Front Needle Bearing {1532}84.) R.H. rear Needle Bearing {1532}85.) Oil Filter Fitting86.) Dowel Pin87. - 88.) Ditto 82 - 83 for Left-hand89.) Ditto 84 but uses {8049}90.) Ditto 86 for Left-hand Edited March 15, 2017 by "D"- Man Pics 1 Share this post Link to post Share on other sites
"D"- Man 827 #36 Posted March 15, 2017 (edited) Does anyone know what the Allen set screw is for {just below the lower bearing Pic #1 and to right of right bearing in Pic #2} Edited March 16, 2017 by "D"- Man 2 Share this post Link to post Share on other sites
"D"- Man 827 #37 Posted March 23, 2017 (edited) Assembled the Parking brake / pawl and seal, to case half. I was not able to get the 5959 seal, but I did use a new one for the shaft. Next is the axle seals. Edited March 23, 2017 by "D"- Man 1 Share this post Link to post Share on other sites
pfrederi 21,051 #38 Posted March 23, 2017 16 hours ago, "D"- Man said: Assembled the Parking brake / pawl and seal, to case half. I was not able to get the 5959 seal, but I did use a new one for the shaft. Next is the axle seals. Parking brake seal 5959 is CR4911 less than $3 1 Share this post Link to post Share on other sites
"D"- Man 827 #39 Posted March 23, 2017 Thanks Paul, I was not able to get a 5959 but I was able to order a couple replacement seals from a fellow member of RS. These did not have the metal surround but they are essentially the same size I.D & O.D in a bit less thickness. Share this post Link to post Share on other sites
"D"- Man 827 #40 Posted March 24, 2017 On 3/15/2017 at 4:57 PM, "D"- Man said: Does anyone know what the Allen set screw is for {just below the lower bearing Pic #1 and to right of right bearing in Pic #2} Found out that the set screw is just a plug, it serves no purpose. This was told to me by the gentleman who designed the forward-swept axle that Wheel Horse liked and used. Share this post Link to post Share on other sites
"D"- Man 827 #41 Posted March 25, 2017 On 2/26/2017 at 10:48 PM, "D"- Man said: Had an issue with a leak in one of the front tires, after sanding the bead area on the rim, repainting, and reassembly of the tire to the wheel, I tested it in water and found out that the leak was due to a faulty core in the valve stem. I also was able to purchase a couple of the #104396 Ball Flange bearings {New Old Stock} but had already taken pics with the used before they arrived.48.) Left Spindle49.) Left Inner Shim .05050.) Left Inner Shim .01551.) Left Wheel Assembly52.) Grease Zirk53.) Zirk Installed54.) Valve Stem {Non O.E.M.} I have C3 Corvette Flags valve stem caps I will be using instead of the plain chrome shown55.) Valve Assembly Installed56.) N.O.S. Ball Flange bearings57.) Bearings Installed58.) Tire Installed on Wheel59.) Wheel Tire Assembly on Spindle60.) Left Outer Shim .01561.) Left Outer Shim .05062.) Left Thick Washer63.) Nyloc Hex Bolt {Non O.E.M.} Greased Bearings64.) Hub Cap {New Old Stock}65 - 81.) Ditto for Right Side You can click on pics to enlargeNext update, (if any - not really noticing much interest in these updates, compared to the amount of time, effort and expense required to produce a resto-mod of this magnitude} may be awhile as I have quite a bit of sorting to do with the hydro transaxle and dual ag tires / wheels before I can proceed. I did not have all 4 bearings new {part #104396} just 2, these are no longer made that I know of. I was surfing through eBay and saw the part # for this bearing, I could not believe the price... ... until I noticed it said SET OF 4 I also noticed it was a Buy-It-Now so knowing I only needed 2 more for a full set to complete the front of the resto-mod I "Bought-It-Then" as opposed to trying to buy just 2. The 2 remaining New Old Stock bearings will be spares. I still need the 2 nyloc bolts {part #908033-6 or simply 908033}, I am just using non OEM until??? Share this post Link to post Share on other sites
pfrederi 21,051 #42 Posted March 25, 2017 I use these. Better than $3 ea for Toro new #110242 2 Share this post Link to post Share on other sites
"D"- Man 827 #43 Posted March 25, 2017 1 hour ago, pfrederi said: I use these. Better than $3 ea for Toro new #110242 Thanks, Paul, the manual states the specs are for 3/8" - 16 x 7/8" did you use the 3/4" or the 1"? Share this post Link to post Share on other sites
pfrederi 21,051 #44 Posted March 25, 2017 I have bought a box of both. The one inch will usually work if it bottoms I add a shim or two. Have used the 3/4 also doubt eh 1/8" makes a difference. 1 Share this post Link to post Share on other sites
"D"- Man 827 #45 Posted March 26, 2017 Have finally assembled the transaxle with the extra long axles for duals. Share this post Link to post Share on other sites
Aldon 4,832 #46 Posted March 27, 2017 Very nice work and great pics. Thanks for taking the time to do it. 1 Share this post Link to post Share on other sites
"D"- Man 827 #47 Posted March 27, 2017 82.) Right-hand Transaxle Case 83.) R.H. Front Needle Bearing {1532} Installed, outside, inside 84.) R.H. rear Needle Bearing {1532} Installed, outside, inside 85.) Oil Filter Fitting, Installed 86.) Dowel Pin, Installed 87. - 88.) Ditto 82 - 83 for Left-hand 89.) Ditto 84 but uses {8049} 90.) Ditto 86 for Left-hand Parking Brake Pawl 91.) Parking pawl 92.) Parking shaft 93.) Spirol pin 94.) Installed 95.) Seal 96.) Inserted in case 97.) Shaft inserted in case 98.) Brake lever assembly 99.) Spirol pin 100.) Inserted in lever 101.) Installed on shaft Share this post Link to post Share on other sites
"D"- Man 827 #48 Posted March 27, 2017 2 hours ago, Aldon said: Very nice work and great pics. Thanks for taking the time to do it. Aldon, You are welcome. I have more pics; but, I may have met the max limit or something, Tried to purchase R.S. support; but, stated," You are only allowed to purchase one of this product, and you have already done so." Don't know what I am doing wrong... Share this post Link to post Share on other sites
Aldon 4,832 #49 Posted March 27, 2017 Maybe PM @nylyon 1 Share this post Link to post Share on other sites
woodchuckfarmer 333 #50 Posted March 27, 2017 I tried to renew mine and it said the same thing. Share this post Link to post Share on other sites
