johnclinster
Wheelhorse Bronco 1972 14hp Kohler no spark
johnclinster
I have no spark, and am new to this, i tested the coil and there is no amperage, I also did the spark plug block test..., no spark. But cranks perfectly, and lights work great, Any Ideas what could be the the official problem?
WH nut
For test purpose, run a jumper wire from Battery + to the + side of the coil and see if you have spark. If you do, back track to the ign. switch. Must have 12 volt to the + side of the coil.
johnclinster
Hey whnut, I appreciate you getting back to me, I did the test that you said and I am not getting spark that way either, just to let you know I have a brand new coil, spark plug, spark plug wire, and battery hooked up
gwest_ca
Remove the spark plug so you can easily turn the motor over by hand.
Turn the ignition key to RUN
Check for voltage at the (+) coil terminal. If yes
Check the voltage at the (-) coil terminal as you rotate the engine slowly by hand for at least 2 complete revolutions. When the ignition points are closed there should be no voltage. When the points are open there should be voltage. This happens once for every 2 revolutions of the crankshaft.
If the voltage does not go to 0 volts the point contacts need to be cleaned with a file or crocus cloth. There will be invisible oxidation on them preventing electrical contact. Point gap should be .018" to .020" when they are open at their widest point.
The condenser connects to the (-) coil terminal along with the points.
Power from the ignition switch goes to (+) coil terminal.
Let us know what you find.
Garry
johnclinster
I am convinced with the test you mentioned that the points need to be cleaned, where Exactly are they located, are they inside of the engine too? I found the casing on the front of the engine and some metal mechanism inside, I am having a hard time finding any pictures, I appreciate your help
johnclinster
Hey Garry, just wanted to let you know that the problem was the points gap, and they needed cleaned, I also cleaned up the magneto and the flywheel, it runs perfectly, thank you all for your time and help
gwest_ca
Glad to hear you have it fixed. If the battery powers the ignition coil this is called a battery style ignition so you won't have a magneto. Magneto ignitions are self-powered and any battery power to them burns up the magneto coil. Very important to identify the type of ignition used in case you have other gasoline powered equipment.
Garry
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
