bmsgaffer 2,069 #26 Posted May 7, 2015 Yeah think that flange type would work and may be able to find a heavy duty two holer. A full length keyed shaft would do unless you have means or someone to cut them where needed. Either a drop down plate (perch) to mount or through frame as needed to align with engine pulley plane. The extra pulley sounds kinda what I was thinkin too. On the tran if you can find a good roller for around $100 would give you a good tran maybe but then you'd have another one to fix up, Ha, ain't these things a joy. Also there are a lot of folks on forum that deal withtrans that may be close enough to go after. Fastenal ships stuff for a very reasonable price if you can find someone willing to take it to Fastenal and fill out paper work. Kelly, member on here has a heard his wittling down. Believe he is still selling parts, shoot him a PM, nere's his ad post him what you need. Prices run from $75 and up, brake "drum", input pulley, brake band, shift handles are other things may come with or without that are price drivers also. You could also place a "wanted" ad in classified and see what pops up. Tex still has a lot hidin out there, La is very sparse to zero, Mo is a "hot bed" , and Ok pops in quit often (all this mainly tractors, some rollers). I'll keep perusing/trollin and holler at ya if find any thing that might suit yer needs! From for sale classified: He's a hop skip and a jump across the big pond.... I dont think fastenal goes there at the moment (and thus why its so hard to find stuff) Share this post Link to post Share on other sites
callum12 257 #27 Posted May 7, 2015 that is a big problem over here, parts etc. anyway here is the pictures as promised: hope these help, Callum 1 Share this post Link to post Share on other sites
callum12 257 #28 Posted May 14, 2015 got a uni-drive! not an 8 speed but 4 speed the type that has the same casing as 8 speed not the 3 piece ones. got everything i need except for the 5 lug 1" hubs. since I will be doing this mod for sure all my posts to do with the transmission will be on the "project Agri-800" post under 'modifications and customisations'. thank you all for your help, callum 1 Share this post Link to post Share on other sites
