Navig8r 132 #1 Posted April 22, 2015 Sunday, I pulled the belt cover, and the bolts from the rear cylinder covers to get a look and clean if necessary..... Pretty happy with what I found! Has about 320 hours on it, and my grandfather used to carry a whisk-broom with him when he mowed so he could brush the grass off the intake! I then changed the oil and filter, put in fresh plugs, and got the garden tilled! Woohoo! Share this post Link to post Share on other sites
JackC 616 #2 Posted April 23, 2015 Those are pretty clean fins. Apparently the engine has not developed any oil leaks. Here are some pics of an ONAN P216 engine with about 1,000 hours on it and the prior owner did not get the memo about cleaning the fins. So, if the cooling fins are not kept clean and get to look like this (I already scraped some grime off the bottom before taking the picture): Then the engine will overheat and the inside of your engine will look like this. 1 Share this post Link to post Share on other sites
Niagara D 11 #3 Posted April 23, 2015 Hey mine looks like that after just 5 minutes snowblowing on the first snowfall this past winter. Still looking for a new engine as the block and crank are toast as a result. Share this post Link to post Share on other sites
boomers_influence 106 #4 Posted April 24, 2015 jack 99% of the time the broken rod is caused by lack of oil in the oil pan. thank you boomer ( the used onan engine parts guy,also NOS and new ) 2 Share this post Link to post Share on other sites
JackC 616 #5 Posted April 25, 2015 jack 99% of the time the broken rod is caused by lack of oil in the oil pan. thank you boomer ( the used onan engine parts guy,also NOS and new boomer, I do plan to totally disassemble it as a low priority learning experience. I will then spec everything to see how bad things are and if it is worth putting back together. I do not really need the engine or the tractor it came off of. I do like my ONANs so the more I know about them the better. At least if I need parts sounds like you are the guy. I know there are a few out on the internet but have you thought about making and selling how to videos for us ONAN fans? Thanks Jack Share this post Link to post Share on other sites
