Dieselcowboy 211 #1 Posted April 13, 2015 Where could I find how fast a stock tractor goes? I'm wanting to spray with one of my horses and need to be in the 4.5 - 5 mph range Share this post Link to post Share on other sites
stevasaurus 23,534 #2 Posted April 13, 2015 It might say on the 1st page of the manual for your horse. If not, you could use a GPS while riding...it will tell you your speed. Share this post Link to post Share on other sites
Forest Road 595 #3 Posted April 13, 2015 It is listed in owners manuals. Top speed is 5.5. If it's really important I'd check it w a gps. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Hodge71 691 #4 Posted April 13, 2015 It is listed in owners manuals. Top speed is 5.5. If it's really important I'd check it w a gps. Sent from my iPhone using Tapatalk Unless its a D series, GT-14 or a 520HC. Then is much quicker Share this post Link to post Share on other sites
Dieselcowboy 211 #5 Posted April 13, 2015 My top choice to use is a 753 4 sp next is a C160 auto or a b-80 4 sp Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #6 Posted April 13, 2015 The 854 should be the same as the 753 and the OM says forward speed up to 6 mph. Garry Share this post Link to post Share on other sites
Tankman 3,527 #7 Posted April 13, 2015 (edited) Your avatar 520-8? Great Horse! APPROXIMATE GROUND SPEEDS (at Full Throttle) Gear Low Range High Range 1st .5 mph (.8 kph) 2 mph (3.2 kph) 2nd .8 mph (1.3 kph) 3.2 mph (5.7 kph) 3rd 1.4mph (2.2 kph) 5.5 mph (8.8 kph) Rev. . 7 mph (1.1 kph) 2.6 mph (4.2 kph) Sorry, speeds above for the 520-8. Edited April 13, 2015 by Tankman Share this post Link to post Share on other sites
shallowwatersailor 3,219 #8 Posted April 13, 2015 That looks to be correct for all the 8-speed transmissions. I just finished fertilizing using my broadcast spreader and the ground speed called for is 3 mph. I use my C-105 specifically for that purpose in 2nd Gear High Range. Also add the 5xi to the speedy tractors as the top speed is 7.2 mph in Hi Range, Lo is 4.4 mph. Share this post Link to post Share on other sites
Dans wheelhorse 5 #9 Posted April 14, 2015 Those still won't beat a d-250.... 1 Share this post Link to post Share on other sites
papaglide 542 #10 Posted April 14, 2015 My 522xi hasn't even approached 7mph. Bummer. It probably hits around 5. I will check it out with my gps thought. Share this post Link to post Share on other sites
Dieselcowboy 211 #11 Posted April 15, 2015 Here is what it will be. The 753 2 Share this post Link to post Share on other sites
shallowwatersailor 3,219 #12 Posted April 15, 2015 My 522xi hasn't even approached 7mph. Bummer. It probably hits around 5. I will check it out with my gps thought. Mike, did you ever adjust the pedal play? That may be the reason for not getting the speed. I know that my 523Dxi currently has undersized ags (23x8.50-12) on it and is slower than the other two. Share this post Link to post Share on other sites
papaglide 542 #13 Posted April 15, 2015 (edited) John, I have been fiddling with it since I bought it. I measured with the gps,last evening and this is what I got: Hi- 6mph in F and 3 in R Lo- 3mph in F and 1 in R I guess that it was faster than I thought. Edited April 16, 2015 by papaglide Share this post Link to post Share on other sites
Save Old Iron 1,573 #14 Posted April 15, 2015 Regulation of ground speed is all fine and dandy. How are you going to assure your dispense rate stays constant? Without consistency in both, you cannot achieve even broadcast of your payload. Share this post Link to post Share on other sites
Tankman 3,527 #15 Posted July 9, 2015 Retired, enjoy maintaining the Horses. They need it, they get it!Speed? I really don't care. Settle in for all the seat time I can get, or the grandsons, or sons. We all need seat time, ride 'em cowboys!Today I was offered a D-250 ran great with a jump start, dead battery. Owner uses Kubota's now and, if I ask, probably zero bucks or, pay me sometime.Should I pick the Stallion up? I never cared for Renault. Guess I'll get the Horse dropped off then find room in my barn. I am part German so...................... 1 Share this post Link to post Share on other sites
KC9KAS 4,745 #16 Posted July 10, 2015 Retired, enjoy maintaining the Horses. They need it, they get it!Speed? I really don't care. Settle in for all the seat time I can get, or the grandsons, or sons. We all need seat time, ride 'em cowboys!Today I was offered a D-250 ran great with a jump start, dead battery. Owner uses Kubota's now and, if I ask, probably zero bucks or, pay me sometime.Should I pick the Stallion up? I never cared for Renault. Guess I'll get the Horse dropped off then find room in my barn. I am part German so...................... You better get that D-250 before he sells it to someone else! 1 Share this post Link to post Share on other sites
