BOWTIE 226 #1 Posted April 12, 2015 I HAVE A PROBLEM WITH MY FRIENDS 1995 314-8 (M14 KOHLER) WHEEL HORSE. VERY LOW FUEL PRESSURE WHEN CRANKING ENGINE OVER WITH THE STARTER. JUST A TRICKLE OUT THE OUTLET NOZZLE. I REMOVE THE FUEL PUMP AND PUMP BY HAND AND SQUIRTS 2 FOOT OR SO. THIS IS A NEW PUMP TODAY. THE OLD PUMP DID THE SAME THING. DO THE FUEL PUMP CAM WEAR OUT ON THECAMSHAFT? I'M THINKING A CHEAP BASIC ELECTRIC PUMP. BOWTIE IN CENTRAL OHIO Share this post Link to post Share on other sites
Forest Road 595 #3 Posted April 12, 2015 X2! I have an electric fuel pump on the shelf. Just havent had time to install it. Share this post Link to post Share on other sites
skrusins 128 #4 Posted April 12, 2015 I have a 1995 314H and install it under the seat with no problems. They push better than suck. 1 Share this post Link to post Share on other sites
BOWTIE 226 #5 Posted April 17, 2015 THE PROBLEM WAS THE OLD FUEL PUMP WAS BAD, THEN THE NEW TAIWAN FUEL PUMP WAS BAD. IT HAD 5/16" PLAY IN THE ARM BEFORE IT WOULD PUMP. THE CAMSHAFT LUBE FOR THE PUMP ONLY AS 5/16" LIFT. THAT WHY IT JUST HAD A TRICKLE OF FUEL WHEN CRANKING THE ENGINE OVER. I CONFIRMED THIS BY TRYING IT ON ANOTHER ENGINE WITH THE SAME RESULTS. SENT THE NEW PUMP BACK TO SUPPLIER FOR A REFUND. PUT A USED ONE ON IT. Share this post Link to post Share on other sites
Marv 994 #6 Posted April 18, 2015 I like electric. I have three tractors with them. Will put them on the others as I get to it. Marvin Share this post Link to post Share on other sites
