white-box
Snow Cab Interchange on 1987 310 to a 418A?
white-box
I have been looking for a snow cab.  Seller has one off an 87-310-8.  I want to mount it preferably on my 87-418-A.  Did they make different sizes for different tractors?  Does anyone have a chart to see what they fit?
I have 2 other machines that are similar sizes but I was hoping to dedicate the 418-A to exclusively snow work.  It is an amazing tool.  My son runs it all day and collects close to a $100 per driveway in big storms.  Amazing tool!
post-10323-0-64504100-1428541475_thumb.j
post-10323-0-22275900-1428542071_thumb.j
Edited by white-box
zieg72
Should fit perfectly.  Same hoods and overall shape..
white-box
I also have an 88-516-H and an 88-520-H.  So you would guess it would fit any of the 3?
MalMac
It will fit if it's of the newer style with the plastic top. If it has a Fiberglas top it is of the older design and the cab is smaller, it was made for the older C series. It will fit but might need some tweaking here and there.
608KEB
This is the cab off my 93 520H. It does have a fiberglass top. I also have a cab off a 95 520H with a plastic top.
post-5623-0-97285700-1429121392_thumb.jp
post-5623-0-53007100-1429121706_thumb.jp
Edited by 608KEB
  • Similar Content
    • Brooklyn581
      By Brooklyn581
      Rear mount leaf collection system blower. Trailer with Canvas avail for an additional $100.
      $200 for both or Would trade both for a snow thrower attachment that mounts to the older style long frame for a Wheel Horse Charger 12. Upstate NY Pick Up only.
      Excellent condition. Even the decals are original.
    • Mjhinno
      By Mjhinno
      Excellent condition Wheel Horse OEM blower and bagger system removed off my 520H because I don't mow my yard any longer. Includes all mounting brackets for bags and blower, along with double pulley and belt for deck. Bags are good and intact and show some fraying along top frame edge. No cracks in the bagger hood or deck to bag chute. Blower blades are straight, balanced and complete. Best to text or email me
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Upnorthman
      By Upnorthman
      314-8 In great shape. Used for mowing more than anything. Bought it a few years ago but got a new tractor. I used the blower very little and it sounds like it needs a bearing on it. Runs well. I have new chains I've not put on yet and extra belts.
