pfrederi 19,278 #1 Posted April 4, 2015 (edited) I know that Kohler produced a fuel pump plate used to cover the hole in the block if the motor didn't use a fuel pump. My question is there a similar plate for the Twins? I have put on an electric pump and it would be nice to remove the mechanical one...if I could cover the hole. Edited April 4, 2015 by pfrederi Share this post Link to post Share on other sites
JackC 617 #2 Posted April 4, 2015 The show up on eBay from time to time or you can get one from Kirk Engines. http://www.kirkengines.com/index.php#AluminumCovers Share this post Link to post Share on other sites
pfrederi 19,278 #3 Posted April 4, 2015 The kirk engine ones are for the K series singles. Share this post Link to post Share on other sites
JackC 617 #4 Posted April 5, 2015 The KT17-19 are flat head twins and use the same style fuel pump as the single cylinder K engines. What engine do you have? Share this post Link to post Share on other sites
WH nut 553 #5 Posted April 5, 2015 Why go through the trouble, just let it hang there it wont hurt a thing. Share this post Link to post Share on other sites
pfrederi 19,278 #6 Posted April 5, 2015 The KT17-19 are flat head twins and use the same style fuel pump as the single cylinder K engines. What engine do you have? Magnum 18 Share this post Link to post Share on other sites
JackC 617 #7 Posted April 5, 2015 The Magnum takes the same style fuel pump as the K's. The Magnum engines are basically the same engine as the K-series. The main differences are, besides the sheet metal that covers the block, the Magnum has solid state electronic ignition, a fixed main jet (Walbro) carburetor and the starter fastens to the bearing plate instead of the engine block. Most of the external and all the internal parts are interchangeable. Besides Kirk's, Millers also sells the cover plates.. http://gardentractorpullingtips.com/carbfuel.htm 1 Share this post Link to post Share on other sites
meadowfield 2,931 #8 Posted April 5, 2015 Or make one, just draw around a gasket drill the holes and cut it out. I did the same thing! 1 Share this post Link to post Share on other sites
pfrederi 19,278 #9 Posted April 6, 2015 The Magnum takes the same style fuel pump as the K's. The Magnum engines are basically the same engine as the K-series. The main differences are, besides the sheet metal that covers the block, the Magnum has solid state electronic ignition, a fixed main jet (Walbro) carburetor and the starter fastens to the bearing plate instead of the engine block. Most of the external and all the internal parts are interchangeable. Besides Kirk's, Millers also sells the cover plates.. http://gardentractorpullingtips.com/carbfuel.htm Thank you!!! Share this post Link to post Share on other sites
