Apbrown 0 #1 Posted March 31, 2015 (edited) I bought this 1994 264H off craigslist. The seller had taken it in trade for some automotive work he had done for the original owner. Looks like the owner took good care of it and I will do the same. I have a question. I ran it around for about ten minutes after getting it home and the top of the transaxle between the rear wheels is smoking a little. The seller greased everything and changed all of the fluids prior to selling it so I assume he could have spilled some fluid on the case. Does the hydo-transmission on these get hot enough to smoke if there were fluid spilt on top of them? Also, there is a slight high pitch squeal while the PTO is engaged, I assume this is a belt that needs adjusting. Am I correct? Thanks in advance for your input. Andy Edited March 31, 2015 by Apbrown Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #2 Posted April 1, 2015 Welcome to the forum. Here are some manuals on your model and links to others Garry 1 Share this post Link to post Share on other sites
Apbrown 0 #3 Posted April 1, 2015 Thank you for the welcome and for the links. I will look to see if I can find the operating temperature of the transmission. I dont want to ruin my machine, so I stopped running it until I can figure out if it is supposed to be getting hot enough to smoke. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #4 Posted April 1, 2015 Here is another version of the transmission service manual published by Tuff Torq. I have not compared it to the Toro version. Garry 1 Share this post Link to post Share on other sites
953 nut 69,031 #5 Posted April 2, 2015 Not only a new member, a like new . You may want check the fluid level, it could be too high causing some overflow. 1 Share this post Link to post Share on other sites
Apbrown 0 #6 Posted April 3, 2015 Thank you for the Welcome 953 nut. I need to mow my field for Easter weekend. I will recheck all the fluids and see how it goes. Do I need to check the fluid inside the transaxle case or just the transmission resevoir under the hood? Thanks again, Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,589 #7 Posted April 3, 2015 Wellcome to red square , nice rig. Best of luck with it. Really low hours. Wait till you buy your next one. Glenn 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,279 #8 Posted April 3, 2015 Not to familiar with the 264, but is there a cooling fan under the fender that blows on the hydro pump? Make sure its working (if it has one) Mike......... 1 Share this post Link to post Share on other sites
Apbrown 0 #9 Posted April 3, 2015 I have seen a cooling fan in the manuals for the 264, I will locate it tonight and ensure it is turning. Thanks! Share this post Link to post Share on other sites
