cimby5 0 #1 Posted March 27, 2015 So our 310-8 will start and run for 35-45 minutes and then shut off. It will start back up, but only with full choke, but it won't stay running long. If I let it sit for an hour or so, it will start and run for another 35-45 minutes. I've already started working backwards and have so far cleaned the carburetor, installed a new fuel pump, coil, and spark plug, as well as replaced the fuel line and a new filter. The in-tank screen is not clogged ( I drained the tank and the fuel easily flowed from the petcock). I have also tried running it with the fuel cap loose, just in case the vent in the cap is clogged. So far, nothing has worked. Ideas? Share this post Link to post Share on other sites
WH nut 553 #2 Posted March 27, 2015 have you checked the muffler to see if its plugged. That's about they only thing you haven't covered Share this post Link to post Share on other sites
cimby5 0 #3 Posted March 27, 2015 Haven't yet, but I will tonight. Thanks. Share this post Link to post Share on other sites
Wishin4a416 2,189 #4 Posted March 27, 2015 Are you using a big fuel filter? Mine did the same thing and I had to go to a little B&S pancake filter. Share this post Link to post Share on other sites
cimby5 0 #5 Posted March 27, 2015 I have a bigger one on now, probably 2 1/4" long x 1 1/2" dia. May have to pick up a smaller one to try. Thanks. Share this post Link to post Share on other sites
tunahead72 2,346 #6 Posted March 28, 2015 Points and condenser? Which engine, K series or Magnum? Share this post Link to post Share on other sites
cimby5 0 #7 Posted March 28, 2015 I wasn't able to get to the parts store in time last evening to pick up a pancake B&S filter, but had a somewhat smaller filter in the garage. Put it on and had the tractor running for over an hour. Not sure if the filter was no good from the factory, or if I just needed something a little smaller. Either way, it ran for much longer than it had been. Thanks for all the suggestions/help. With all the new parts, I shouldn't have to replace anything for quite a while. Share this post Link to post Share on other sites
