84 400 0 #1 Posted October 30, 2008 I am going to be ordering some aggie tires and I want to get a set of used rims to clean and mount them on. what is the stock size rims? Are these the same ? http://cgi.ebay.com/Wheel-Horse-Work-Horse...id=p3286.c0.m14 Thanks for the help Ian T Share this post Link to post Share on other sites
84 400 0 #2 Posted October 30, 2008 I see i must of had caps lock on. the tractor is a 552. thanks i Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #3 Posted October 30, 2008 No problem, I fixed the topic title. Share this post Link to post Share on other sites
linen beige 16 #4 Posted October 30, 2008 No problem, I fixed the topic title. So you call yourself an r-teeeast huh? But can you make silly faces and noises while "dancing"? Ian T, Those rims are wider than the original rims for your 552. These will mount a 23x8.50x12 tire, which is wider than your stock 6x12s. If the back spacing is right they can be used, but you will have to buy wider, more expensive tires. Look for a set of 5x12 rims to mount your original width tires. They are usually advertised as early, narrow rims. There was a rim that was even more narrow than these and mounted a 5x12 but they are pretty seldom seen. The ones you want were used on all the round hoods from '58 (Maybe even earlier?) 'til '64 and are pretty common. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #5 Posted October 30, 2008 So you call yourself an r-teeeast huh? But can you make silly faces and noises while "dancing"? If I do any dancing, you better believe there will be silly faces and noises....and not necessary from me. :banghead: Share this post Link to post Share on other sites
linen beige 16 #6 Posted October 30, 2008 If I do any dancing, you better believe there will be silly faces and noises....and not necessary from me. :banghead: Share this post Link to post Share on other sites
84 400 0 #7 Posted October 30, 2008 thanks alot for the info everyone! and for fixing the title How about front rim size? I would go and look but I am away until thanksgiving and want to order some parts so that I can get rolling on this project. thanks Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #8 Posted October 30, 2008 I think Jim posted the rim size as 5 x 12. Share this post Link to post Share on other sites
linen beige 16 #9 Posted October 31, 2008 I think Jim posted the rim size as 5 x 12. That's for the rear tires. The rear tire size should be 6x12, but the rim size is slightly narrower than 6 inches. Going from fuzzy memory that's about five inches? For the front the tire size should be 4x4.80x8. the rims are 8 inches diameter, x I think 3 1/2 inches width between the beads. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #10 Posted October 31, 2008 Ah, man. I missed the one key word - "front". Now I feel :imstupid: Thanks, Jim, for pointing him in the right direction. Share this post Link to post Share on other sites
84 400 0 #11 Posted November 1, 2008 Thanks alot guys for clearing that up. My front rim is in pretty bad shape. the grease fitting snapped off and it is flaking rust chunks. It still has the original good year tires and I would keep them if not for the valve stem leak. maybe they wilt clean up and I can just replace the stem. thanks again Ian Share this post Link to post Share on other sites
CasualObserver 3,414 #12 Posted November 1, 2008 If they've got good tread then by all means keep them.... take the stem out and put a tube in them. 4x8 tubes are pretty cheap. Share this post Link to post Share on other sites
