OhioGuy89 4 #1 Posted March 2, 2015 Hi folks, a while back I posted a topic in the main forum called " weird starting noise" to cut it short, I lubed the pinion gear shaft on my starter, and got a New battery. I also tightened the flywheel bolt. When I went to start the tractor just now, I got the following video to show what happened. It seems like my flywheel is loose and not engaging with anything .https://vimeo.com/121082087 Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted March 2, 2015 Maybe the flywheel key is sheared off Share this post Link to post Share on other sites
OhioGuy89 4 #3 Posted March 2, 2015 Hmm. It shouldn't be, since it was on there perfectly when I put it back on. Ill have to take a look Share this post Link to post Share on other sites
JustinW.73 224 #4 Posted March 7, 2015 That can still happen. They are just aluminium. Did the engine pop a couple times before not engaging? Share this post Link to post Share on other sites
