boatmoter 0 #1 Posted March 1, 2015 have a k-301 on a 1975 JD 212 that I want some more HP out of the old beast.., what I would like to do is use a k-341 bare block and use all the goodies out of the k-301 in it other than the piston,rod & head, will the bearing covers and oil pan and Flywheel,crank, well, pretty much everything interchange?? Share this post Link to post Share on other sites
Fordiesel69 272 #2 Posted March 2, 2015 Tins, starter, bearing plate, fuel pump, dipstick, oil pan, gov gear, gov linkage, etc..... should all fit. Crank, piston, rod, head, valves, carb, air filter tin, etc should be specific to the K341. 1 Share this post Link to post Share on other sites
Don1977 606 #3 Posted March 2, 2015 The 301 crank has the bottom of the weights milled off and is too light in weight for the 341. The same with the 321. 2 Share this post Link to post Share on other sites
boatmoter 0 #4 Posted March 2, 2015 Thanx guys.. Im going to add up what I have to buy and the cost & compare it to the price of a complete engine... thanks again.. Share this post Link to post Share on other sites
