psalms83:18 174 #1 Posted February 27, 2015 Two owners ago the guy shmucked this D-160 up!! Foot press button ignition screwed onto a wooden block on the side and the key start still works!! But the starter made a horrible grind noise. I look under and the starter is wiggly"". So I see the oil filter and filter mount has been previously removed..... Maybe the starter has been replaced before? Maybe you could tell from the pics? I remove the filter assembly and barely manage to get the starter off with removing the whole flywheel cover peice. Kinda helped to get it out the starter bracket is broke! Maybe someone hit it to get it workin again. I could tell when it was spinning it was slipping across the teeth of the flywheel but it didn't seem to wear any down too bad, or break any. Is it possible that this starter was a newer one put on and they didn't put on the right one?? Think it's possible to buy just the bracket? Or do any of you have a good used one? Share this post Link to post Share on other sites
JackC 617 #2 Posted February 27, 2015 Wow. Never saw a break like that before. I have never seen just the bracket for sale anywhere. There are good new and used starters on eBay. When I replaced my starter I removed the exhaust, removed the front frame, disconnected the drive coupling, and moved the engine forward a little in order to access and replace the starter and to secure the mounting bolts properly. Share this post Link to post Share on other sites
pfrederi 18,707 #3 Posted February 27, 2015 D160s depending on year had either a Kohler or Onan engine...Which is yours? Share this post Link to post Share on other sites
boomers_influence 106 #4 Posted February 27, 2015 psalms by looking at the drive end of your starter, i can tell it was made in crapland. there SHOULD be a boot on the end to seal the shaft. it does not have the correct hardware to even use the boot. i do offer the onan end plate as well as the end kit. boomers_influence@yahoo.com 651 437 2826 thank you. boomer ( the used onan engine parts guy ) Share this post Link to post Share on other sites
psalms83:18 174 #5 Posted February 28, 2015 (edited) pfrederi : its an onan Boomers: can u post some pics of what u got and what do you mean you have a "end plate"' (too what?) Edited February 28, 2015 by psalms83:18 Share this post Link to post Share on other sites
boomers_influence 106 #6 Posted February 28, 2015 psalms i DID give you my e/mail FOR A REASON. please reply, and i will send you a page from the parts manual. thank you boomer Share this post Link to post Share on other sites
psalms83:18 174 #7 Posted March 1, 2015 (edited) Just cause you so "SERIOUS " with it I will email you when possible. though I prefer the info on here for everyone's benefit. AND!! I don't like giving out my personal info. Edited March 1, 2015 by psalms83:18 Share this post Link to post Share on other sites
psalms83:18 174 #8 Posted March 2, 2015 Wow 50$ on eBay.... And bummer Sears used to stock just that end cap bracket!! But not anymore Share this post Link to post Share on other sites
psalms83:18 174 #9 Posted March 6, 2015 Well I got the starter temporarily repaired! I used some JB weld 😯 first time I have ever used it. I cleaned then baked the pieces then cleaned them again!! Took extra care to mate the peices and cleaned up the edges. Installed it today and it works! Kinda surprised actually, it was a desperate move. Hah lol and I surely wasn't ballsy enough to say I was gonna try it before it actually worked! Otherwise if it failed it would never of been known! But it works good so far Share this post Link to post Share on other sites
bmsgaffer 2,053 #10 Posted March 7, 2015 I would be very interested to see how long that lasts! Impressive commercial for JB Weld! 1 Share this post Link to post Share on other sites
boomers_influence 106 #11 Posted March 7, 2015 how much does JB weld cost? how much time for clean and bake? do you have the correct starter to pan bolts? also, you are still missing the drive end kit. thank you. boomer Share this post Link to post Share on other sites
psalms83:18 174 #12 Posted March 8, 2015 (edited) 5$ Walmart 5min 500deg And it's what was on it was working before it broke, it's working now! I'm very thankful for that! And thanks boomer for being there with the parts if I went that route! Edited March 8, 2015 by psalms83:18 Share this post Link to post Share on other sites
