19richie66 17,816 #1 Posted February 12, 2015 Anyone know the diameter of the crankshaft of the 420 where the PTO is mounted? Reason I ask is I have a magnum 20 and I would like to run a wheelhorse pto set up on it but the crank is 1-7/16" diameter. Is the 20 horse in the 420 the same? I found the part number for the pto sleeve/bearing for the 420 but I cannot find a size spec. Thanks, Richie And no, I do not have a 420 LSE. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #2 Posted February 12, 2015 The 6658 bearing race # 6658 also fit the 1990 312-8 so it is for a 1-1/8" diameter crankshaft. I think the only other race was for a 1" diameter crankshaft on the 8hp models. Garry Share this post Link to post Share on other sites
19richie66 17,816 #3 Posted February 12, 2015 Thanks Gary. Guess that idea is out. Back to the drawing board. Share this post Link to post Share on other sites
ericj 1,579 #4 Posted February 12, 2015 j d ran the larger cranks on the onans and the k532 kohlers that i know of eric j Share this post Link to post Share on other sites
Callen 64 #6 Posted February 13, 2015 (edited) Was thinking the 520HC had a 1-7/16 crank. It used a different spec number than the 520h, anyway. Edited February 13, 2015 by Callen Share this post Link to post Share on other sites
baerpath 517 #7 Posted February 13, 2015 Cranks can be cut down. I watched a old guy do one, started the engine and used a 4 inch grinder then finished it with grit. I'd have sworn that it wouldn't work but the engines still working for him. Started as 1 1/2 and cut down to 1 1/8. Share this post Link to post Share on other sites
19richie66 17,816 #8 Posted February 13, 2015 I checked the toro website and they show the same crank bearing race for the h and hc #6658. No biggie. Ill just go a different route with my idea. Thanks though! Share this post Link to post Share on other sites
psalms83:18 174 #9 Posted February 13, 2015 My c175 race and a c81 both had the same outer diameter but had different inner diameters. Maybe a different model might have one that will fit? Maybe I'm not thinking on the same page as the rest of you? 2cents Share this post Link to post Share on other sites
