chev0545 236 #1 Posted February 5, 2015 there is no tag on seat pan. here is the motor tag model # p220g spec # 1/109550 serial # g893575970 thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,456 #2 Posted February 5, 2015 109550 is not correct. Could be 10955C used in 1991 model 41-20OE02 and 1992 model 41-20OE03 10955D used in 1993-1995 model 73501 10955G used in 1996 model 73501 and 1996-1997 model 73502 Garry Share this post Link to post Share on other sites
chev0545 236 #3 Posted February 5, 2015 you were right it's a c thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,456 #4 Posted February 5, 2015 In your search for info @ Toro there is occasions where a serial number is required. For 1991 use 1012345 with model number 41-20OE02 - Notice the O is for Onan For 1992 use 2012345 with model number 41-20OE03 Once upon a time I had a list of Onan serial numbers but can't find it now. The letter starting the serial number changed each year so suspect that is how the year of manufacture was recorded. They did start at A I believe and advanced each year but don't remember when it started. That won't guarantee tractor model year as the engines are always built a few months before the tractor but an engine built in 1992 sure didn't end up on a 1991 model. The 1991 models would have been released in October of 1990 and 1992 models in October of 1991 like they do with autos today. Garry Share this post Link to post Share on other sites
chev0545 236 #5 Posted February 6, 2015 both model # are invalid Share this post Link to post Share on other sites
Kurt-NEPA 755 #6 Posted February 6, 2015 Dave, Will any of these model numbers help. 41-20OE02, 1991 520H 41-20OE03, 1992 520-H (SN 2000001-2999999) 73501, 1993 520-H (SN 39000001-39999999) Share this post Link to post Share on other sites
cheesegrader 433 #7 Posted February 8, 2015 (edited) for the 91' 520H serial numbers are 1000001 to 1999999 My numbers will work on the Toro site 1991 520H Model 41-20OE02 Serial 1032376 Be sure to be careful entering the number zero and the letter "O" You also have to use the - after the first two numbers For model 73501, you have to enter a 7 digit serial number, even if your tag only has 6 digits (grrrrrrr...don't ask how long it took me to figure this out!) For example, the tag on my '94 is serial 4901137 49 for the '94 model run, tractor 1137 in the run The Toro site won't work unless you enter a 7digit serial number on 520 tractors Just add an extra zero, and it will work (49001137) Edited February 8, 2015 by cheesegrader Share this post Link to post Share on other sites
