saminmn 17 #1 Posted February 3, 2015 I have a gt14 we pulled out of the woods this summer but the tow valve will not move .Which way should the lever turn? clock or counter Share this post Link to post Share on other sites
JustinW.73 224 #2 Posted February 3, 2015 Should be counter but i could be wrong. Just do it slowly tho. You shouldn't hurt anything. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted February 3, 2015 It will actually turn completely around. It needs to be turned 90* to go from "Go to Tow" or "Tow to Go". Right now I can't remember if it needs to be parallel or perpendictular with the frame for towing. Share this post Link to post Share on other sites
Shynon 7,542 #4 Posted February 3, 2015 180 parallel with frame Share this post Link to post Share on other sites
daveoman1966 3,882 #5 Posted February 3, 2015 If the tow valve is stuck, use a crescent wrench to back off (out) the top nut several turns. The whole valve comes out, then cleaned it up refit it. 2 Share this post Link to post Share on other sites
meadowfield 2,953 #6 Posted February 3, 2015 btw,the later ones were different, they were 1/2 turn on the piston-piston sundstrands 1 Share this post Link to post Share on other sites
